Been on here a while, don't post very often, but lurk around.
I currently have Rays Engineering CE28N's on my 34GTT, which I believe are 18x8 and 18x9 unsure of offset.
10470912_10154206675295231_6558176008423
I am thinking about buying new wheels but I am unsure of what offset to fit, and if I can fit under the guards. I am thinking something a great deal more aggressive
Keeping in mind my guards have already been rolled, in Japan.
Was thinking of getting these Rota Grid-R's in these offsets, but perhaps there is a better suited offset on the website.
18x9.5 +18 front
18x10 +15 rears
http://www.rotawheels.com.au/wheels/rota-grid-r
Would like similar fitment to this, maybe perhaps slightly less aggressive.
Nissan Skyline R32 fitted with ROTA Grid R 18 x 10, 5x114.3 +15 Cosmic Blue
My question is how far can I push the offsets?
Also will 18x10's fit under my R34GTT, or is that pushing it too far for the rear, and perhaps 9.5 is too much on the front also?
Cheers in advance,
Michael.
Edited by Illest
https://www.sau.com.au/forums/topic/451782-r34-gtt-wheel-offset-advice/
There is a huge thread dedicated to offsets for skylines here - http://www.sau.com.au/forums/topic/84208-wheel-sizes-offsets-for-skylines/
But in short, the 10+15 will be too wide unless you plan on aggressively flaring your guards. The 9.5+18 will still be very aggressive, but if you want to give up some function for form, camber will make them fit. I have 9.5+20 with around -1.5deg camber on the fronts and they still poke around 10mm.
Thanks for the reply mate, I had checked out the other other forum but didn't find anything close to the specs I was looking for.
Yours sits pretty well!
9.5" will be the way to go then, with +18 or +15 offset, this whole business confuses the hell out of me.
Cheers,
Michael
Edited by Illest
Basically, the lower the offset (the +18 part), the FURTHER out the rim will sit. So if we compare 9.5+30 and 9.5+10, the +10 will sit 20mm closer to the guard than the +30.
And just to confuse you, this number is dependent on the width of the wheel - so 9.5+22 is the same as 10.5+34 (as you are adding an inch of width, the offset is 12mm higher because 1 inch = 12.7mm)
Use this website - willtheyfit.com to chose the offset right for you. There is plenty of information on that thread, you are not looking hard enough.
Cheers,
Michael
Judging by your profile, what you want is the lowest offset with the widest wheel width, combined with the narrowest tyres size.
SO like a 185 wide tyre on a 10.5" wide wheel, because it'll match your bumhole stretch.
Complete shot in the dark, but did/do you know someone called Micheal Tran?
Mate to start with take your current wheel off & your offset should be stamped or written on the inside and width. Then go online and find a offset calculator, it will asked you to put in your current specs then it will tell you were your new wheel specs will sit. Remember if it's not aggressive enough you can always add spacers later. But you can't go back .
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
