Ta Ben...
so these are all relevant to Skylines as well, not just the Audi in the article?
Says "for all turbo cars".
Have a read over the table at the bottom of Part 2, it has a good side-by-side comparison.
Mmm think I'll give this a shot. For <$100 you cant go wrong.
My current DS BC is pretty average. Hopefully its not that hard to install and can be swapped over pretty easily?
Just need it before my SAFC install next week...
BOO57A, any ideas where the parts can be found quickly?
Brisbane
49 Annie Street Coopers Plains, 4108 Brisbane:
Tel: 07 3875 1977 Fax: 07 3875 1431
Web: www.norgren.com/au
Email: [email protected]
Edit: Did you read "Part #2" regarding the upgrades?
Ihave set up 2 R33's and an R32 with the improved setup from part 2 and they work very well. You can set your max boost very accurately and also set up the way boost comes on . You can also change its sensitivity eg you can have boost on all the time just touching the go pedal or you can hold it off until half throttle or full throttle . You can have it comming on early and building up steadily with revs or comming on with a huge bang at 5000 or anything inbetween.
I have the Norgren catalog and also a spare setup if anyone local is interested...Shane??
addit. If you use the one way valve you probably don't need the more expensive Metalwork regulator the Norgren is good enough
  • 6 months later...
About how long does it take to set up this part 2 and approx cost of all the components?
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
