Ok ok, before you flame me, I have read the Power FC FAQs. This is an Apexi Power FC D-Jetro for and RB26/30 in an S14. Engine starts and idles fine with the stock ECU, plug in the Power FC, and it just starts and immediately dies. I have turned the boost control feature off. I am using 1000cc injectors and have set the injectors to 44%. I am using the GM 3 bar map sensors, which have not been calibrated in the hand controller because apparently I need a dataloggit. I have the signal wires of the map sensors going into pins 27 (black wire) and 35 (orange wire). I have checked all power and ground connections, all are ok. Anyone have any incite into this? Would be greatly appreciated.
The map sensor not being calibrated is the problem.
Being the sensor used to determine load how do you expect the power fc to know what's going on with the engine with it not calibrated?
Yuh, it's like hooking the PFC up to the bench vice in your shed and expecting it to work.
mine worked fine when I did this. but it had a random cough so I replaced it with a haltech
  • Like 3
I thought it should still start though as load is also determined by TPS input. And I thought it silly that the Power FC NEEDS to have those sensors hooked up and calibrated just to start and idle. But I guess with it being older technology, it is what it is.
What if a sensor goes bad when starring the car 300 miles from home? That would suck lol......
Like any car if the main load sensor fails the car typically won't run.
It's nothing to with being old. Load is a function of the map sensor influenced by throttle position. how can you think it's silly it doesn't work without its main sensor?
The engine also determines fuelling based on its rpm input.
If that wasn't connected do you think the car would run?
Edited by Ben C34
Just sell it and buy something more modern.. but the time you buy the cable and/or datalogit etc.. blah blah blah and find out you need inputs for your wideband/flex sensor/secondary speed sensor you'll just end up selling it anyway
  • Like 1
Finally got a Datalogit installed and changed the MAP PIM scale and offset numbers on option 1. Changed to 6630 and 0 (off the top of my head) and she still just cuts off immediately after it catches during start up. Any ideas now?
I have had little luck getting my engines to start on the base maps for the d-jetro. I found it best to completely do away with the base map in the ECU, and start again from scratch. Its pretty easy to do once you get the engine to idle. To do that though you need to know how to set it up.
Turn on a watch in the datalogit, and watch Injector MS. Make note of what it is doing during initial starting and when it stalls out. See if it goes to <2ms or even zero.
Having a wideband O2 can help too, as you can see if it goes super lean before cutting out.
Finally there is the fuel/ignition lockout method. Set all your fuel base MS to 2.00ms for the 1200 RPM and below range, and ignition at 20 degrees for the same range. This will allow your MAP sensor to be ignored and essentially locks your fuel/ignition delivery with fixed values to allow you to get the car to idle.
Start the car, and note the O2 meter (if you have one). Increase the fuel MS for the locked out range gradually if need be (if it keeps stalling out). Once its running properly, you will be able to determine what the load point is that the MAP sensor will operate at when idling.
Then break out a timing light and set your base ignition to 20 degrees, and adjust your fuel again to get it idling nice. If you have no wideband, you can reduce fuel little by little for the idle load point while watching RPM. Keep reducing fuel while RPM increases until it stops increasing. Then add about 0.1ms.
Once you have it idling, you can adjust your MAP sensor Offset value such to put the idle load point at the second from the bottom load range. Turn on another watch, and monitor the PIM value. Use this value to modify the offset for the Map sensor to move the load point. Engines with stock cams will pull a -18inHG vacuum, so the second from the bottom load point is a good place to set it too. Larger cammed engines will have less vacuum, so set it at the 3rd load point for those.
my suggestion
1. perform DATA INIT
2. turn car off
3. turn car to ON, but don't start it
4. set map sensor settings via datalogit (or hand controller)
5. set boost kit off
6. check SENSOR SW CHECK and make sure no sensors are black highlighted
7. start car and perform self idle adjust process (this is documented in the FAQ)
then it should be stable and it should idle
note the self idle adjust is meant to run for 30 minutes......
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
