Hi everyone,
just want to install Greddy Profec boost controller on my M35. here is some installation information:
actually i am not sure which is fuel pressure regulator that need to connect to boost controller. i took a picture and marked 2 pipes in red and green. could anyone told me which is correct pipe connect to fuel pressure regulator? thanks all.
Also doesn't matter. Just needs to be plumbed to the manifold somewhere to measure vacuum and boost.
Either you have marked is fine
Edited by Ben C34
i think i could get you. actually this is for monitor the boost in manifold? and i could also connect this vacuum with boost gauge vacuum together?
  • Like 1
Please have a look at the attached photos. I hope this helps you with your install
thanks mate. i think i could get you. in your pic, you just changed solenoid only? For Greddy boost controller, the control unit need another vacuum pipe connect between manifold and fuel pressure regulator to measure the boost. and another question, shall i need to remove the stock boost sensor?
Edited by YangLIU
You dont have to remove it, I did as I replaced mine with the hdi-ebc-d due to the oem unit always malfunctioning. I haven't had an issue since replacing it with the hdi unit. The hdi unit seems like a simpler install. That hose i mentioned earlier would be the one you are looking for then if thats the case
Edited by joshm35
The signal line to the ebc has to come from the manifold.
The pressure source to the solenoid has to come from the turbo.
That's important, and not very clear from above pics. What ever line you use on the manifold for the ebc makes no difference. Then use the line to the stock solenoid for the new solenoid.
Actually, I don't like using the fuel reg line for the manifold pressure reading anyway, as that long hose you are fitting can slow the reg's reaction down. Also if it leaks it will lean out your engine.
I prefer to use the front bung normally used for the stock boost gauge. You might need an adapter though, it's tiny. The BOV line is another you could use, who cares if that leaks.
Make sure you put a cable tie around the hoses to the reg, they have been popping off a lot lately.
yup. thats what i am thinking. actually it is hard to use fuel reg line due to the narrow area. i already have a new boost gauge using stock boost gauge vacuum. now i consider to use BOV vacuum for EBC pressure reading.
i know what you are talking about. actually Greddy EBC has 2 part for installation. 1 for solenoid, 1 for pressure signal reading. my original question is for pressure signal reading part. and your pic is for solenoid part. here is a part of Greddy EBC installation manual. I think M35 should use METHOD2 as below and it is same as your pic, right?
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
