Hi Guys,
I am just about to become the owner of a very tidy 1993 GTR VSpec and wanted to know the exact differences between the standard model & VSpec model. I know the VSpecs are supposed to be relatively rare, but for what reason? Probably due to the limited numbers Nissan built, but what extra goodies did they actually come with over the standard model?
Thanks in advance.
BBS wheels, forgot about that.
17x8 (same set as Stagea 260RS IIRC).
Gauges and attesa are same I'm sure, not that you can tell the difference.
Brembo Front and Rear Calipers.
17 x 8 +30 BBS Wheels (Check the centre of the wheels for correct wheel sizing)
V-Spec Sticker on the boot lid.
A retuned ATTESA E-TS system.
In short not much. They are however pretty cool, especially if you keep them bone stock and clean.
Also, there is another post on here where someone gets a reply from Nissan regarding the differences. They state ATTESA is the same as the standard model.
http://www.sau.com.au/forums/topic/415962-r32-gt-r-v-spec-differences-and-specs-nissan-japans-advice-to-me/
  • Like 1
Stiffer suspension... I see.
And yes of course, bigger tyres, to fit on to biggers wheels.
Ok, so looks like the coolest thing is saying I have a VSpec?!?! Lucky I think thats pretty cool;) Pick it up Saturday and will begin the process of cleaning out my funds to build an immaculate GTR!!! Oh make that, a R32 GTR VSpec;)
Thx Guys!!
  • Like 1
"...in February 1993 the GT-R V-spec (for Victory) emerged wearing 17" BBS mesh wheels(225/50/17) covering larger Brembo brakes. The clutch actuation changed from a push to a pull system, the car had the standard rear differential, the electronic rear differential did not show up until the R33 Vspec. A year later the V-Spec II appeared with a new sticker and wider tires (245/45 17)..."
Wiki is king.
  • Like 1
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
