Hi All,
I've had some recent issues with my series 1 R33 that has me thinking that the CAS is dying and needs to be replaced, however I'm looking for a second opinion before I go out and source a replacement.
It started running rough the other night on the highway randomly after driving for around 20 minutes. It was running low on fuel at the time, so as it runs on E85 I assumed it was possibly picking up some water/crud from the tank and limped it over to a mates house quickly. After filling it up with a jerry can of E85 about 30 minutes later, I started it up and gave it a rev and all was fine once again. I ended up driving it back home about 5 hours later and it didn't have any problems for the remainder of the drive (about 30 minutes).
Fast forward to yesterday and my old man takes it for a drive after its sat for a day or two and once again it runs fine for about 15 minutes then starts running really rough. I looked over it yesterday after its been sitting for about an hour and it's still running rough this time. I end up replacing the fuel filter just in case its clogged up and there is no change - fuel pressure at the rail is around 44psi which is spot on apparently and I cannot see any problems with the fuel system (has an E85 460lph Walbro installed). I move onto the spark plugs which appear to be fine and then check and replace the coil packs with known good spares to check that a coil hasn't died and it makes no difference (currently has ~2 month old yellow jackets). I then attempted to disconnect a plug for each cylinder to determine if there was a particular cylinder dropping but it doesn't seem to be any particular one. I also checked the ECU (Link G4+ plugin) which doesn't register any relevant error codes.
After another hour or so of checking lines, wiring, etc I start it back up and its now running worse than ever - barely idling and struggles to rev at all (feels like all the timing has been pulled).
Based on the above I assume its the CAS that's dying, however would love a second opinion/sanity check of the above!
TL;DR;
RB25DET running badly
Initially only happening after 10-15 mins of driving, now all the time
Have checked ECU, plugs, coil packs, fuel filter, fuel pressure
Assume CAS is dying and want a second opinion
Log your voltage with your ECU, see if the voltage drops as you drive in the higher rpm area.
I had a similar issue where my car would splutter and shit whenever it was warm.
Turned out my alterntor was cactus and voltage dropped to 12.2 volts after 4000rpm or so
So you have the software for the link on a laptop? I would start by looking at everything you can on the link software wbile while its having the problem. In one of the top drop down menus there is 'view parameters' or something along those lines which has a heap of tabs with all the stats of the car. Start with that
Have you done simple things like pulling individual coilpack plugs out while running to see if one doesnt change the engine note.
You can idividually check injectors in the link software. I think in aux outputs - fuel there is an injector test option
The link software is great for testing outputs. Can check whats working (options for test pwm or test that just turns it on)
Depends...I replaced a CAS on an RB25DET which was running rough. When we got the CAS off it felt like a stuffed wheel bearing - turned roughly and sometimes caught almost solid.
  • 4 weeks later...
For anyone that cares it turned out to be the ignitor.
I bought a replacement ignitor from a parts shop that was supposed to be "tested in working condition", but it seems it was just as broken as the one I had on. Workshop put a brand new one on and it runs perfectly now.
  • Like 2
Also FYI
I had the exact same issues on my 34.
34s ingiter is built into the coilpacks.
My issue was related to my injectors being blocked from E85 when i change my engine with a different fuel tank, same symptons as you.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
