  • 1 month later...
in Qld, call the Council and get them to send the fire ant dept out ;) works a treat.
But seriously I don't know. We used to get them around every now and then when I lived in the suburbs.
The pest crews that is, not the ants.
https://www.sau.com.au/forums/topic/451886-fire-ants/#findComment-7464264
We have the inch ants here, they really don't bother you if you leave them alone, just another part of our ecosystem.
If they are a issue some rid ant at the site should sort it out, better than ULP and a match because it doesn't contaminate your garden with petrochemicals.
The kids are playing with them now, they run along a stick and you keep grabbing the opposite end, you have to keep the stick at arms length because after a while they get frustrated with you, and as Mick said, they then look at you and jump.
  • Like 1
https://www.sau.com.au/forums/topic/451886-fire-ants/#findComment-7466826
They have stingers in their abdomens like wasps, I was once crawling around on the ground at night and ended up on a nest, I got bit and stung on the hands, neck and face pretty bad, no fun was had.
  • Like 1
https://www.sau.com.au/forums/topic/451886-fire-ants/#findComment-7466888
  • 1 year later...
Difficult to kill in Qld over 10 yrs and still going.
Now in Perth and Port Botany in Sydney.
How do you or would you kill off the nests?
you probably still did not get a answer u looking for :
but i found how to control them around my house
1: petrol works only for about 6mths and they back in the same hole about 2ltrs i used and a match
2. insecticide i do my own pest control but i still think public should be banned and should be controlled better i buy my chemicals from LANDMARK agg store A. its cheap B. better range.
ok so buy some insecticide eg. group 3B, 3A , 2A so on now remember the group class you used this year to kill the ants coz the following year you need to use another class coz you dont what them to get immuned self educated on that and there's not much info on this so if anyone knows more teach me more apart from the 3hr to find government documents.
ok now you got your $50 1ltrs good shit mix it up like it says 80mls to 5ltrs
get your sprayer spray a nice mist around your houses window paving eves eta.. then pour about 0.5ltrs of milky water into each hole you find then next time you see them do the same but with a different class i did it 2 years in a row damm fire ants are back after 5yrs Perth
btw i redo my house every 6mths to protect from spiders small ants that looking for food scraps cockroaches eta....
Edited by pol1on1
  • Like 2
https://www.sau.com.au/forums/topic/451886-fire-ants/#findComment-7709746
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
