  • 1 month later...
in Qld, call the Council and get them to send the fire ant dept out ;) works a treat.
But seriously I don't know. We used to get them around every now and then when I lived in the suburbs.
The pest crews that is, not the ants.
https://www.sau.com.au/forums/topic/451886-fire-ants/#findComment-7464264
We have the inch ants here, they really don't bother you if you leave them alone, just another part of our ecosystem.
If they are a issue some rid ant at the site should sort it out, better than ULP and a match because it doesn't contaminate your garden with petrochemicals.
The kids are playing with them now, they run along a stick and you keep grabbing the opposite end, you have to keep the stick at arms length because after a while they get frustrated with you, and as Mick said, they then look at you and jump.
  • Like 1
https://www.sau.com.au/forums/topic/451886-fire-ants/#findComment-7466826
They have stingers in their abdomens like wasps, I was once crawling around on the ground at night and ended up on a nest, I got bit and stung on the hands, neck and face pretty bad, no fun was had.
  • Like 1
https://www.sau.com.au/forums/topic/451886-fire-ants/#findComment-7466888
  • 1 year later...
Difficult to kill in Qld over 10 yrs and still going.
Now in Perth and Port Botany in Sydney.
How do you or would you kill off the nests?
you probably still did not get a answer u looking for :
but i found how to control them around my house
1: petrol works only for about 6mths and they back in the same hole about 2ltrs i used and a match
2. insecticide i do my own pest control but i still think public should be banned and should be controlled better i buy my chemicals from LANDMARK agg store A. its cheap B. better range.
ok so buy some insecticide eg. group 3B, 3A , 2A so on now remember the group class you used this year to kill the ants coz the following year you need to use another class coz you dont what them to get immuned self educated on that and there's not much info on this so if anyone knows more teach me more apart from the 3hr to find government documents.
ok now you got your $50 1ltrs good shit mix it up like it says 80mls to 5ltrs
get your sprayer spray a nice mist around your houses window paving eves eta.. then pour about 0.5ltrs of milky water into each hole you find then next time you see them do the same but with a different class i did it 2 years in a row damm fire ants are back after 5yrs Perth
btw i redo my house every 6mths to protect from spiders small ants that looking for food scraps cockroaches eta....
Edited by pol1on1
  • Like 2
https://www.sau.com.au/forums/topic/451886-fire-ants/#findComment-7709746
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
