Hi guys,
I'm having a problem after switching the diff on my R33 GTR v-spec to an r32 GTR non-vspec diff with carbonetic LSD center. The preload stays on for too long after an initial start. Then after a few seconds the ABS/4wd/LSD light comes on.
The A-LSD lines from the pump have been blocked off. The system has been bled. The shop has checked all 4 wheel sensors and they are sending pulses. Diff ratios checked and number of "cogs" on the rear ABS same between old and new stud shafts.
Has anyone had a similar issue when swapping the diff and center? Do I need to swap to a non-vspec Attesa computer?
I'm stumped.
https://www.sau.com.au/forums/topic/451895-v-spec-diff-swap-4wd-problem/
Isn't the problem simply that 33 vspec had an active diff, and all the other diffs are normal? Surely the issue relates to whatever wiring differences there are in making the diff "active". Or is the only difference at the diff the hydraulic lines?
That's part of what I wanted to know. Do I have to find a R33 non-vspec Attesa computer? The only wiring on the rear diff was the ABS sensors and we left those in place.
I thought that the Attesa computer would just send signals to the pump (that's blocked off) and that would be it. The sensors in the diff are the same. So it is just the mechanical A-LSD is shunt off.
I would suggest that it is failing the startup tests where it is probably cycling the A-LSD solenoid and not seeing the result it expects (probably a pressure change or something else that it can monitor). Then it says "My solenoid is borked" or something and faults out.
Take it to a mechanic and put a code scanner on it. You will be able to interrogate all the CUs on the car, find the fault code.
  On 19/12/2014 at 2:53 AM, Pezhead said:
I'm running an Autronic computer so no ODBII fault diagnostic. Where is the "light" on the Attesa computer under the parcel shelf. I looked for it but didn't see any LED lights.
Doesn't matter. Has nothing to do with the ECU. Plug a decent code scanner into the Consult port and you will be able to see all CUs that are connected to that bus. ABS, TCS, Auto, ECU, ATTESA, HICAS, whatever is there.
I haven't used Consult, I thought it was on the stock ECU.
Now there isn't a bleed plug on the diff - since it is replaced with a non A-LSD R32 unit. The bleed for the Attessa is on the rear of the trans. What bleed plug are you referring? Is there an electronic bit there?
I had Award diff do the work. Terry said that they've done a fair few of these conversions but never run into this issue. It has us both scratching our heads a bit.
you can not bleed the A-LSD if there isn't one, but the ATTESA has to be bled after removing the diff, the A-LSD also has it own light so the ATTESA one coming on means the issue is the ATTESA and the bleed plug for both is, oh shit you have a 33, I think it is behind the fuse box lid under the steering wheel, white plug with one wire in and one out wraped in foam tape
Consult is Nissan's equivalent of OBDII. It's a bus that connects to all the CUs. I hooked one up to my car and saw the TCU and the HICAS as well as the ECU. Could pull codes from all of them (and both the TCU and HCU were full of them because of what had been done to those systems!)
Hmm, so do I bleed the system from the one bleed nipple off the back of the transmission? I've done it before with unplugging the bleed wire option. So I'll need to see how they blocked the A-LSD and see if I can somehow bleed the blocked line.
Nah nah sorry no, they use the same wire plug to activate the pump for both ATTESA and A-LSD, but bleed nipple I two spots, one on transfer case and one on top of diff, plus one at pump for the gravity feed to the pump, it's the wire plug used for bleeding that I was talking about, check it is connected
It has the ATTESA pro with the faster ECU, the hydraulic pump that controls the 4WD also controls the A-LSD which is hydraulically activated, same pump different valve so realisticly it shouldn't unless the pump is unplugged which is why I thought it might be electrical, since it is reading something on the dash then the pump is plugged in, maybe the pressure sensor ?
I am about to do this myself and would really like to know the outcome
So here is the really strange thing. I bled the system but fluid does just keep coming out without the system even on. And the weird bit is that the front shaft is engaged all the time. Seems like my transfer case is locked on. I had this problem when I first rebuilt it, but another shop determined that the case was put together incorrectly and fixed it.
It was working fine immediately after the diff change cause I pulled the front drive shaft to drive it to the tuner immediately after. But when I was going to put the shaft back in after the tune was the first I noticed it.
Any ideas?
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
