Michael, looks like I owe you a round. I rotated the sensors and ran around the block where the error used to show in first 100 meters.
Now I need to change the connector on the old sensors and the reinstall.
Thanks!
  • Like 1
So checked the resistance on the sensors. R33 were 1.3k ohm and the R32 were 2.1k ohm. So I opted to make some 90 degree adapter plates instead of swapping the connector to put the R32 ones in.
Fingers crossed that this finally sorted it out.
Also the bolt thread are in the A-LSD half shafts where the non are in the CV
Most people would just put the diff in with the sensors that came with it so it probably hasn't been an issue yet :/
Yeah my A-LSD stopped working once I put the LSD up front, which I found out at SMSP-S last year :(
Yeah that'd be why - most just swap the entire diff.
lol - Is there ANYONE with a v-spec who hasn't gone through that agonising experience? :D
  • Like 1
Well I can confirm that the sensors have sorted out my dramas. The car ran all day Saturday at the Nulon nationals without a single Attesa error. All the rear 1.5 way goodness really helped on the wet Skidpan.
  • Like 1
  • 3 years later...
On 1/13/2015 at 11:37 AM, Pezhead said:
Yup changed my half shafts cause the alsd diff is so much wider.
What shafts did you end up using? Did you get non v-spec R33 ones. I'm just about to go through this conversion now. I have an R32 GTR diff that I am installing
Yup, ended up picking up some non V-Spec R33 GTR shafts and chucking the V-Spec ones.
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
