act seems weird :D
all they did for mine was eng/vin number check, made sure there was no oil leaks, did a brakes test, wheelbase check, lights test and told me that i should prob remove my ebc cos cops dont like them ;)
none of this "wheres ur owners manual stuff... weird
btw i thought 4 seaters arent allowed to have baby capsule restraints?
  • 2 months later...
I just called the Registry and spoke to a young lady.
She was very helpful. Informed me that I DO NOT need to go over Dickson. Any authorised inspection station is fine.
This was because the vehicle has been australian complianced and registered in another state already.
She was quite clear about it.
I wonder if it has something to do with the vehicle being more the 10 years old??
Interesting that you all had to go over Dickson.
Ahh just checked the rego site (http://www.rego.act.gov.au) and they have removed the condition for all imports to go over dickson.
Sorry for giving you wrong information, a few months back it had to be taken over dickson, and also specified it on the above mentioned website.
Right...
So does that mean that even an imported car which has been in australia and registered in say NSW for a few years still requires to go into Dickson for a rego check??
I just purchased an R33 so I'm keen to get rego in the ACT.
Paul
They have taken out the condition that imports must go over dickson, but
any car that has never been rego'd in the A.C.T before must go over dickson for an ID Check before it can be transfered to A.C.T rego.
damn i guess we timed it badly nick?
for those that dont know i registered mine in the ACT about 2months after nicks and i got screwed around bigtime in regard to not knowing where to go. in the end they were ok with me at dickson, a young guy dave who works there was simply wonderfull to deal with.
but its much more helpfull to be able go to a mechanic and have it checked, and 1st things 1st i'd like to recomend ed out at integra automotive in queenbeyan. as many of the guys will agree (esp nick and ewan) he's a great guy, a great mechanic, and it would be a very good idea for you to have him do the inspec for you.
can he do ACT checks even though hes in queanbeyan?
what we need is a real skyline owner's manual. something that contains more info than the stock bits of rubbish people seem to be getting. something people can download off a site, print it off, bind it and keep in their glove box.
my manual isn't bad, fairly detailed. the pix are a bit rubbish though (photocopy of a photocopy). probably wouldn't be that tough to collate some of the stuff on this forum into a proper manual.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
