Hey guys, after some side fed 555cc or 740cc nismo or Jecs injectors. Years ago I,bought them off a sponsor / trader but can't seem to find any on here. I could be blind or daft.
I'm just after a reliable source and a genuine item.
I am aware this is probably the 124,433rd post about this but reliable sellers come and go quickly these days.
Thanks.
https://www.sau.com.au/forums/topic/451911-best-place-to-buy-injectors/
I have Nismo 740s ill be selling in the new year. Would be lucky to have done 10,000km. Only a year old
Im going bosch injectors because they are better but if you want to keep stock rail etc then id be happy to sell you mine in early/mid january
Big fan of ur car 89cal. May I ask....what benefit would u be getting out of Bosch injectors as opposed to the side fed ones...I mean is it worth the money/hassle...considering ur car probably runs fine with the current ones.
I've had nismo 555cc's previous and never had an issue. Ran like a Swiss watch with 304rwkw. I just fail to see why I would change. I'm not fighting it... I just don't understand the major differences is all.
Forgive my ignorance.
The Nismo's will work, and they have worked for me. But the new style injectors just handle the smaller pulse widths so much better which is good for fuel economy and idle. These are my main reasons for switching, I'm sure there are some more.
Come to think of it, I'm not real sure why Nismo (JECS) have never bothered to update to newer style injectors, maybe they arent as easy to do in side feed, im not sure, but seems like they are going to start losing some business because of how resonably priced some of the newer injectors are getting these days.
When I bought everything for my engine I didn't think twice about going Nismo's again, they worked before when I had 555's and seemed cheaper at the time rather then having to buy a rail etc. But I'd just started hearing so many good things about the Bosch EV14's that I had to jump ship. I'm yet to try them and fully appreciate them but I don't think so many people can be wrong about them.
I think Scotty NM35 is able to do some pretty good deals on injectors, although I got my kit of Kudos Motorsport at a pretty decent price.
If you want the Nismo's and can wait I will happily sell you mine, but if you want to go new top feeds then I understand as well
Side feeds are gay when you go into the bigger capacity region.. I learnt the hard way, and here's an article I wrote on how to get top feeds into a R33 using the stock plenum...
http://www.trak-life.com/diy-converting-top-feed-injectors-r33-gts-t-skyline-rb25det/
There's kits available now too. Check out KudosMotorsports.
don't think Andrew's kits fit under the stock plenum
  • Like 1
Your injectors sounded especially average :P
My Nismo's are nothing to complain about really. The car idles and drives fine, im sure modern injectors would improve it but its certainly not a pig
  • Like 1
This is the main hassle.
I can do a kit for the short 1400's, as I fitted a set to a 33 and made the spacers to suit, but the 1000's will be slightly different length, and I don't want to get the spacers wrong... Once I have the length for the stubby Bosch ev14's I will be able to do those for very competitive prices. If anyone in Melbourne needs a set fitted give me a PM, it will help with more options for topfeed conversions.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
