Hey guys, I recently bought an R34 and it has had its engine light on since I bought it, ive checked the code and it comes up with error code 14 which is the vehicle speed sensor. I have read a few other forums and ive heard that If the previous owner was a smoker there is a chance it is clogged up?
If I clear the codes the come on randomly again while driving, and there are no other error codes.
Someone help?
https://www.sau.com.au/forums/topic/451913-r34-speed-sensor-error-code-14/
Clogged up from smoke seems unlikely.
The signal to the ecu comes from the cluster. If the cluster is working then that's good.
I would use an oscilloscope to see if the pin on the ecu is getting a signal and go from there. An auto electrician might be required depending on your skill level and equipment.
