So i rigged up this simple, free incar mount for my gopro today and figured it was worth sharing.
You will need:
A drill;
screwdrivers;
the plastic base that your gopro came attached to in the box;
About 20minutes
Remove your interior light fitting. Grab the black base that your gopro was attached to in the box. Mark and drill two holes in the appropriate location. Mount it to the roof in place of the interior light. The plastic is quite soft so I suggest a couple of big washers and dont overtighten. Use the supplied mounts and arms to position the camera.
  • Like 6
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/
Nice Idea. I've been thinking of doing that one myself. You might want to buy an extra long extension off ebay to get it down a bit, but not too far, the spot metering gets a bit confused if there is too much overglare from direct sunlight.
I'll be doing something similar soon. Thanks for posting it up.
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/#findComment-7448578
  • 1 month later...
So, I finally got around to fabricating a mount. I tried the plastic like you but didnt like the wobble cause the base isn't as snug as the mounts that come with the go pro.
I made an aluminium base plate from a bit of angle and cut one side of angle down so it tucks up inside the headliner space. I then moutedan 8 inch magic arm. Will be testing this at some upcomeing motorsport event.
this is the view
  • Like 1
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/#findComment-7489053
yeah the plastic base is quite soft so Im unsure how it will go with vibration etc. I've only done a few short road tests so far and its been fine but I'm going to try it out at the track end of this month and see how it goes. How did you attach the magic arm to the baseplate?
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/#findComment-7490998
This video will give you an idea. The base plate still moves around a little so I might put an extra two screws in to make it more secure.
I had another video that had a bit more vibration in it. Mind you, I use the curbs and on semi's you'll see the G-meter holding 2G's for over a full second.
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/#findComment-7496403
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
