Alright so i need help with my fuel return. I bought and rb20det and when i went to start it up for the first time it ran like shit. I had the injectors professionally cleaned as two were had it so it was running on 4 cyl, but it only seemed to make it run worse. all vac lines are hooked up, plenty of fuel going into the injectors but nothing is coming out of the return line. any ideas? i put new spark plugs in recently and they are already black from fuel.
help much appreciated thanks
https://www.sau.com.au/forums/topic/451937-rb20det-fuel-system-help-needed/
Black plugs is way too rich, so the injectors are too big without some sort of control to make it run right.
sounds like they are using all the fuel, so none is returned.
What mods were done to that motor? Compression test? Leaking injectors? Blocked or kinked fuel line? Clean filters? Afm plugged in?
How did you test fuel pressure?
Rubber hose can kink under suction, like the fuel pump intake.
Once i left a rag in my intake pipe, doh! That made it run like sht.
Are you sure that you have the fuel supply and return connected to the correct side of the rail and reg and so on? Have you put a pressure gauge on it to see if the reg is actually doing anything?
Edited by mattymatty4
the injectors are only stock, no mods to the engine what so ever besides a front mount intercooler. pressure was tested by an auto electrician with a fuel pressure gauge, it showed good pressure but shit fuel flow. i will replace the fuel filter on monday when i can buy one but surely it couldnt just be that could it? i will check the lines for kinked pipes thanks
I'm going to replace the fuel pump and filter, if that doesn't fix it f**k it im going rb25
Your having a minor fuel issue and your going to change the whole engine?
Have you tried revving it and seeing if fuel comes out on engine decel?
Changed the filter, slightly better but still not revving properly down low.
Thanks for the tip cal, fuel is coming out on decel.
Since my plugs are black should i get new ones again?
I think i will replace fuel pump and plugs.
Simple things first. New plugs, gap to .8, try again. If its better then it may have been your plugs or your coilpacks might be a bit sad
Get copper plugs, dont bother with iridium etc. Bcpr6 or bkr6 should be fine. One is slightly longer than the other. Forget which is the more commonly used
Otherwise I can give you the part number for the plugs I get from nissan. They are still ngk plugs but were reccomended by my tuner.
thanks :) my auto electrician friend has 5 new coilpacks (couldn't find the other one) so im going to get some of those plugs you suggested and change the coilpacks, besides one..
With it idling, unplug them one at a time, the one that makes the most difference to engine note/idle will be the strongest. Leave it in. Might not help much at idle but probably how id do it if I didnt want to waste too much time
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
