1 minute ago, Stixbnr32 said:
Looks like a cool kit.  Semi interested as my link is been tuned in 2 weeks.
Hey mate
Unfortunately we wont be ready by then sorry. We are teething a few inconsistent Calibration issues with one ECU we are currently trying. We would like to ensure at least the normally used 3 ECU's used like LINK, Haltech & Motec are all compatible before we go any further.
Regards Stefan
  • 4 months later...
2 hours ago, destrukshn said:
Is there any updates on this Stefan?
Hey Guys
Sorry for no update! gets a bit hectic with so many places to post.
Yes! you can take a look around the website www.iee.nz
We are also on Facebook & Instagram under Innovative Engines & Engineering so you can keep up with our latest products and posts.
NOTE :
For the Australian market Dahtone Racing is our ONLY Dealer and will be taking care of all enquires & orders, he will be live with his website soon also and taking Pre-Orders!
Pre Orders are $450 USD which locks in your DBW kit.
Basic Kits $1530  ( This kit leans towards the track guys, running no heater, and possibly a pedal box to )
https://www.iee.nz/product-page/rb26-gtr-itb-dbw-conversion-system-basic-kit
  • 1 x Electric Throttle Motor Actuator Inc Shaft Support Upgrade & Pivot Lever ( Assembled )
  • 1 x Electric Throttle Motor Actuator Mounting Bracket & Fastner Kit
  • 2 x CNC Machined Aluminium & Electrical Discharge Machined Shaft Connectors
  • 1 xDual Sweep Throttle Position Sensor & Mounting Bracket, Drive-Key & Fastner Kit
  • 1 x Adjustable Rod Linkage
  • 1 x All mounting hardware, Grub screws, Studs, Nuts and Bolts
Full Kit $2250 ( Street GTR application, parts for a full install are covered in this kit, no extra Fab Work and making custom parts is required! drive in drive out bolt in upgrade kit! )
https://www.iee.nz/product-page/rb26-drive-by-wire-system
  • 1 x Throttle Position Sensor & Mounting Bracket, Drive-Key & Fastner Kit
  • 2 x TPS Plugs, Boots & Terminals
  • 1 x Bolt on OEM Style Brake & Clutch Vac Feed Hard Line setup Including Balance Tube Fittings
  • 1 x Balance Tube O Ring Kit
  • 1 x ITB/DBW Compatible Throttle Body Overhaul Complete Kit
  • 1 x Rear Intake Manifold Blanking Plugs
  • 1 x Heater Tube Kit R32, 33 or 34
  • 1x GTR Electronic Pedal Conversion & Grommet Of Your Choice
You can also configure your own kit on the website with fittings and various parts. or ask us for a manual quote.
Pre Sale cost is deducted from the Basic or Full Kit total price, remaining balance must be payed once kits are ready to ship around 15/05/20 - 30/06/20
We have a bunch of other interesting products too! so please feel free to check them out! and give us some feedback, looking forward to hearing from you all.
Kind Regards
Stefan Etter
IEE
Innovative Engines & Engineering.
New Zealand / Switzerland
www.iee.nz
  • Like 1
1 hour ago, Stixbnr32 said:
any issues with these BMW actuators?  I talked to my tuner about this he said they can be shocking bad.
Hey Brent
I could imagine he is talking about the DBW motors that have been in service for 14 - 20 years? As the model they originate from were built from 2000 - 2006, So due to normal wear and tear like any electric motor plus most likely having had a hard life as most BMW M models do, They may reach the end of their life span at some stage.
Personally I've never seen one that's out of order, Even after working for a company in Switzerland called Autotech Und Motorsport Gmbh for 3 years who specialise in hard driven Street and Track application BMW M models.
So my answer is NO they have no issues.
Kind Regards
Stefan Etter
IEE
www.iee.nz
  • Like 1
Thanks Burn4005
Sometimes people rush threw the products and don't read the descriptions. To counteract this contact issue we are working on a solution for the oil cooling system also!
We will be getting around to expanding on our Oil Hard Line kits mid year which we will then supply the following in.
( All of the below is NOT included in the Oil Hard Line Kits which are on pre sale already )
2x - 10 Oil Hard Lines ( Pressure Tested & Cleaned Ready To Fit ) They can be chosen in LH or RH configuration!
3x Chassis Clamps
1x Sandwich Plate With Built In Thermostat
2x -10 Oil Line Hoses from sandwich plate to Oil Hard Lines ( Pre Made, Tested & Cleaned Ready to fit hoses ) Inc Silicone Sleeve over the hoses.
Oil Filters can also be supplied.
NOTE :
Our Kit does not include an oil cooler or mounting kit, Customer or Shop must fit an oil cooler or adapt the existing oil cooler.
In most cases HKS Greddy etc used -12 Hoses, these must be adapted down to -10AN to then transition onto our Hard Lines.
We won't be doing full Oil Cooler Mounting kits or anything like that soon. as that is another huge task and with the amount of bumpers etc avaiable its a fairly big job.
Kind Regards
Stefan
Poor DBW output tuning makes this far more of an issue than a mechanical fault with the gear itself. you should be limiting the half bridge duty when approaching open and closed limits to keep the torque down. driving it hard against the stops (usually from excessive integral gain or poor feed-forward mapping) certainly doesn't help.
Edited by burn4005
  • Like 1
@Stefan Etter Do you have any logs of commanded throttle position vs actual from an ECU, especially at low openings? I'm interested in the control response of this setup under high vacuum conditions specifically for stable idle control. the E46 M3 engine that had a similar setup used an idle control valve for fine airflow adjustment, but it appears there is no auxillary idle air control in this system.
main observations are from the limited pictures i've seen look like the  linkage gain at low openings appear to be quite high (linkage is tangential to actuator arm at low openings) and significant shaft area due to the 6 throttles have a potential to introduce significant stiction. if you have calculated a linkage gain curve for the assembly that would be interesting to see. this may be incorrect on my part and actually be 1:1 through the whole sweep.
Edited by burn4005
Spot on.
So moral of the story is, bring your vehicles to a shop who is experienced with DBW systems.
Thanks @burn4005.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
