Just had a look at an R34 GTT and I am really liking the car and could be a winner as it is the first skyline I have looked at that is running coolant in the radiator.
Everything with the car looks ok, except when the car is idling and the thermo fan kicks in, if you dont give it a good rev the car will stall, he told me its to do with the tuning on the haltech ps2000 and that the tuning isn't compensating and giving a bit more fuel and air when the fan kicks in, is this an easy fix for a tuner?
IF thats the problem it shouldn't be too much of an issue. But I find it weird that a tuner would let it go out with such a basic setting incomplete, not unheard of however.
First skyline that has actually had coolant in it? People cant spend <$100 on coolant etc?
Anyway. It may be a small issue with the tune or he may be blaming the tune when it is something else.
Realistically though it should only be tune, IACV or something along those lines. Its not something that would turn me off the car, but im not sure how mechanically minded you are. do you remember what the idle speed was off the top of your head?
Possibly. Or the altenator load is dragging it down because the tune isnt compensating. However I wouldnt think brake lights would drag it down that much
See if it does the same with headlights + rear demister. If not then quite possibly a vac leak. Should be easy enough to hear with the car off though. If there is no assitance in the pedal with the car off, then a leak seems quite likely
Edited by 89CAL
what the? no.. it's because the voltage is dropping and the tuner hasn't setup the injector dead times properly.. so when voltage drops the injectors are injecting the wrong fuel.. nothing to do with "giving a bit more fuel and air when the fan kicks in".. also you can adjust the idle motor duty cycle on electrical load OR power steering pressure switch input..
Easiest way is to use a diode and pass the negative trigger from the 1/2 thermo fans to the power steering switch input, then enable Power Steering RPM offset in your idle control.. add like 5 or so extra on the duty cycle then presto.
Can't imagine just the thermo load would be so savage to drop RPM instantly, there is a battery to assist after all.
I actually had this issue with my old 180SX running a boat anchor RB20 with the battery in the boot... I had 3x thermos connected to come on all at once when the A/C is on and water temp passed 87 degrees. It was enough to make the car stall - so quick trick was to hook up a trigger from the thermo into the power steering input switch.. worked a treat :)
RB20s are cool little motors mmkay :P
I thought they were cool, till I tried to make it go fast..... wasted effort. It's like trying to make a RB25 go fast, hop into a V8 and you has a sads LOL
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
