Looking to replace or rebuild r32 gtr gear box.
First of all just jap is selling a brand new r33 gtr gearbox for 2.9k (very tempting!) Which i already know is the better beefy box
Or
Can i rebuild my original box the same if not better for the same price as this r33 box
just asking ppls opinions on what i should do as im still new to the gtr scene.
Hope to hear back from yous, cheers
https://www.sau.com.au/forums/topic/451991-need-help-on-gear-box-decision/
Hi Ben, what's wrong with you current gearbox, and what are your future plans for the car?
They are a very strong box from the factory (not many cars come standard with a box that handles 2-3x factory power) so what you have may not need anything, particularly if it doesn't crunch on quick changes from 4th to 5th
If on the other hand you are building another 500kw time attack car, you will need something a bit more expensive.....
Hey theres nothing concerning with my box atm however there is a continuing howling noise coming from that area it could be the pressure plate or it could be manny things my machanic said cant put his finger on it so itll have to come out to find the problem...
theres no crunching ...ive never launched it so it hasnt been abused.
However ill be recoing the car looking to produce 300kw at the wheels or maybe 350kw if im lucky.
Just want everything done once and done right so i can just drive my car and nothing braking . At the end of the day its a 24 year old car and things need to be re-done or replaced.
Cheers, ben
33 gearboxes have been know to be more prone to breaking then 32 gearboxes, you would also need to change the clutch it self and the slave cylinder (unless yours is a 2/93>)
Have you check the basics like it actually having oil in it?
Also of it only needs a set of bearings it will be cheaper to recondition your gearbox
The stock box will be able to do that provided you don't try and rip the gearstick out of the box every time you change gears.
Like everything to do with cars, a little care goes a long way
There are very few differences between standard 32 and 33 gearboxes, and in any case the 32 stuff has been superseded by Nissan with the 33 series 3 internals; so if you rebuild your box you get 33 series 3 stuff anyway.
A standard box is fine for 350kw assuming you are not abusing it (and it sounds like you aren't). If your current gearbox is noisey (bearings) or crunchy (synchros) you can get it rebuilt for under 2k. But in most cases noisey is the thrust bearing which is external to the box and easily replaced, the second most common noise is the front bearing on the gearbox which can also be replaced without much trouble.
BTW you don't have to change the clutch to use a 33 gearbox, they can be converted back to r32 style (pull clutch) by swapping across the front cover of your current box into a 33 one. I bought a brand new 33 box years ago for the race car and did that conversion to suit 32.
Unless you have money burning a hole in your pocket I wouldn't do anything gearbox wise
If you get to this point the answer is Hollinger. As an aside Hollinger distribute Wavetrac - so how do we convince them to sell us some Wavetrac goodness for GTR's?
Edited by djr81
lol you can say it's name, it's the price that hurts....over 20k....
Plus sequentials are illegal in every racing category in Australia except supercars and Porsche cup.....so it would make an expensive trackday car
Bhaha sshiiit 20k later
And so it begins. Take note of the day you laughed at the prospect of spending $20k to fix a GTR.
Yeah but I just want a Wavetrac diff out of them. Which apparently they dont make from GTR's. See here for the full list of fail.
http://www.wavetrac.net/application.htm
Anything close to fitting the rear?
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
