boobeedoobee Posted December 23, 2014 Share Posted December 23, 2014 Hi i have a full exhaust system installed by the previous owner and noticed that the stock converter is still there would replacing it give me much more hp and if so which is a good brand to go go? Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/ Share on other sites More sharing options...
GTSBoy Posted December 23, 2014 Share Posted December 23, 2014 A big 5" 100 or 200 cell cat will give you a little free power, and open up the possibility of flowing a lot more if you add boost/turbo size, etc etc. Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7449909 Share on other sites More sharing options...
boobeedoobee Posted December 23, 2014 Author Share Posted December 23, 2014 Bit odd how it's a full exhaust to the dumps but with an oem cat? Could it be that the oem cat has been punched through like a lot of people do? Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450013 Share on other sites More sharing options...
GTR-N1 Posted December 23, 2014 Share Posted December 23, 2014 Sorry to state the obvious but you'll need to ask the previous owner or take it off and have a look. Is the rear bar coated with yellow residue? Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450020 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 23, 2014 Share Posted December 23, 2014 Bit odd how it's a full exhaust to the dumps but with an oem cat? Could it be that the oem cat has been punched through like a lot of people do? To keep the rear bumper clean and/or previous owner had enough of the exhaust fumes Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450049 Share on other sites More sharing options...
Ben C34 Posted December 23, 2014 Share Posted December 23, 2014 I use a pipe through my stock cat. With approx 45 degree bend at end of exhaust pointing down and no marks at all on the bar. I wouldn't be suppose if your stock cat is hollow. Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450082 Share on other sites More sharing options...
boobeedoobee Posted December 24, 2014 Author Share Posted December 24, 2014 My rear pipe faces down.. and when I warm it up there is lots of black shit on the floor? Does that mean anything? Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450112 Share on other sites More sharing options...
KiwiRS4T Posted December 24, 2014 Share Posted December 24, 2014 If you have a stock cat it presumably bolts up so you can unbolt it in a few minutes and have a look inside. What diameter is your new exhaust system? Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450384 Share on other sites More sharing options...
boobeedoobee Posted December 24, 2014 Author Share Posted December 24, 2014 The exhasut system is a 3inch .. I think Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450456 Share on other sites More sharing options...
XKLABA Posted December 24, 2014 Share Posted December 24, 2014 I use a pipe through my stock cat. With approx 45 degree bend at end of exhaust pointing down and no marks at all on the bar. I wouldn't be suppose if your stock cat is hollow. That in NSW is an instant $10k EPA fine, cat was deliberately modded to not work And for what, there is no gain from a 3" pipe to a working 5" bodied SS cat, 100 or 200 cell makes little difference Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450585 Share on other sites More sharing options...
Ben C34 Posted December 24, 2014 Share Posted December 24, 2014 That in NSW is an instant $10k EPA fine, cat was deliberately modded to not work And for what, there is no gain from a 3" pipe to a working 5" bodied SS cat, 100 or 200 cell makes little difference Yep. I'm in adelaide though, and never known anyone to have any trouble. I think it's pretty common here, which is why I mentioned it. Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450594 Share on other sites More sharing options...
XKLABA Posted December 25, 2014 Share Posted December 25, 2014 Haha, I just noticed he is in SA, so play on Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450607 Share on other sites More sharing options...
Piggaz Posted December 25, 2014 Share Posted December 25, 2014 Is that the actual law? I've never seen the clause of this "$10k fine" for a non working cat. Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450651 Share on other sites More sharing options...
XKLABA Posted December 25, 2014 Share Posted December 25, 2014 There's not working and then there is tampered with to make not work A cat with no center could be argued poor maintance, a cat with a 3" pipe welded inside has been made to not work on purpose And as much as it would be a hard one for them to prove it was you that did it it's not worth the legal battle for no gain in performance over a good quality high flow SS cat Though I do think the full $10k is for a company vehicle Link to comment https://www.sau.com.au/forums/topic/452011-best-catalytic-converter-for-a-32-gtr/#findComment-7450652 Share on other sites More sharing options...
