A Reminder To Check Your Radiator Fan For Cracks And Stress Fractures
I was just doing some routine maintenance and discovered some serious stress fractures and 2 big cracks in the radiator fan base. Obviously if this let go it could cause some serious collateral damage (radiator/hose/water pump/belts etc)
Many of our cars are at the age where plastic parts have experienced numerous heat and stress cycles. The radiator fan is one of the most stressed plastic components in the engine bay. Check not only for cracks but discolouration which is indicative of plastic deformation inside the part.
So take 5 minutes to check yours and replace if necessary. It could save you a lot more than the cost of the fan.
  • Like 1
GKTech make a nice aftermarket fan which also offers higher flow as a benefit.
With mixed results. Certainly not everyone that's used them is happy.
  • Like 1
Cracking on Skyline fans is a common problem (I have more cracked ones than good ones on my cars) and if they let go a high revs they can do some serious damage.
I have seen factory bonnets with major damage from fans letting go - by comparison an aluminium or fibre glass bonnet would just be mince meat with the same impact.
GKTech make an aftermarket fan that moves quite a bit more air volume but it does have its drawbacks. Moving more air generates more noise so it depends on your application. For a normal street car the noise can be a problem but if you have a modified car where engine temps are an issue then they could be the answer to your situation.
Mat, 34GeeTeeTee I believe was not happy with the GKTech.
Not enough Cooling.
The Gktech fans are not a fantastic upgrade for RB or VQ engines as Mattgeeteetee and I both found.
The VQ25det fan is visually almost identical to an RB25det fan, so the shroud clearance and depth are essentially the same. I was also using a brand new Nissan fan clutch.
The gktech fan is identical in dia to the stocker
For starters; LUDICROUSLY loud!
The fan could maintain control over the cooling system whilst moving (mid 80's) (even slowly) but as soon as the car was stationary, the fan would slowly lose control of temperature over about 5 min, until it got to around 95 degrees; then it would skyrocket over 110 degrees in less than 30 secs.
This was using a temp reading from the ECU temp sensor on a perfectly bled cooling system with a Nismo thermostat and brand new 42mm thick dual pass Mishimoto radiator. All in mid 20's ambient temperature; so nothing silly at all.
Change NOTHING but the fan and clutch; cruising temps dropped to 78 deg, and never rose above 86 degrees regardless of how long I sat stationary in traffic. As soon as I start moving; temps drop quickly back to the low 80's.
It isn't silent, but no clutch fan is.
Matt's experience was extremely similar to mine.
They obviously work on SR's, but they are 20mm larger dia than the stock fan; tightening the clearance to the shroud may improve flow, but I don't rate them at all.
  • Like 1
Thats interesting Daleo, i have one on an rb25 and am in Brisbane where at the moment, friggin hot, and often is. I've had no oheating issues and it holds the same spot on the temp gauge. I don't have a digital gauge but when i have monitored temp via consult after drag runs, the temp stays the same/ even as with the stock fan. It is bloody loud tho lol. From your report it might ve worth doing more temp datalogging though.
With regard to the sensitivity of the dash temp gauge; mine (NM35 Stagea) sits in the same spot, 1 needle width below halfway.
It is exactly the same from 73 degrees to 116 degrees.
When bleeding the cooling system the temp spiked briefly to 123 degrees ( recorded as peak hold on Greddy Informeter) and the gauge only rose one graduation.
I believe that the gauge is quite non-linear in the "allowable range" but once you go outside; it ramps aggressively to get your attention.
I have no idea how this relates to the RB gauge.
I would be more curious to see how the GKTech goes on a standard clutch.
Gktech make a CNC'ed billet adaptor to suit the RB Viscous clutch. Around $20 from memory.
I have a Yahsio factory gauge (which uses the ECU sender in the coolant neck) in my car and from about 60 degrees up to about 100 the needle doesn't move at all
Like you, while bleeding it i must've caught a hot air bubble and it spiked to 115 or so and the needle, much like yours hardly moved at all
Take from that what you will, i guess that's why we run aftermarket gauges right? :P
  • Like 1
As for the GKtech fan, like others; I've heard great things for SR's, but not RB's - Stock works perfectly for me, no plan on changing it.
I will however check for cracks or hot spots when i get home after reading this so thanks for the tips!
  • Like 1
  • 9 years later...
I noticed a few cracks in my fan today, which lead me to this post. Has anyone actually seen a fan explode? Is the GKTech replacement still no bueno?
I have seen the aftermath of a rotten old stock fan. It took apart the shroud, wrecked some other stuff (PS or A/C, IIRC) and damaged the bonnet. Not ideal.
Sometimes they die more gracefully. Sometimes they live for years and years looking like they should come apart.
The GKTech fan is not different to how it ever was. At least as far as I know. Whether it is any good or not is more a question of what climate you're using it in. In Canuckistan it seldom gets hot enough for the capability of the fan to matter as much as it does here in Fourex. So you should be able to use it without too much concern. You can always sell it to a driftkid in an S14 if you don't like it.
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
