i have an r33 s1 1993 it has done 175xxxkms and i have had no issues until a couple of months ago when i started the car after stopping off at the shops and it sounded more like a wrx and was shaking like a bitch.. i stopped about 50m up the road and looked under the hood and around the car and figured out it sounded like it was coming from underneath, so i let it sit for awhile and turned it back on, issue still there until i messed around with the immobiliser button and then shifted the gearstick (it is auto) from P to 1 a couple of times which seemed to trip the car back to normal... limped home and hoped it was a one off.
After a couple more times of this happening i figured out it would only happen on the 2nd start for the day, and only if i started it after only a short period of time elapsing inbetween starts... also taking note of the fact the shaking would almost completely go away when the car was above 2500rpm
I have only been driving the car when absolutely necessary and have noticed that the car makes a ticking noise on idle and once the car has turned off, sounds similar to the tick a car makes when cooling down, but is more rapid and coming from underneath the car, im assuming it is coming from the cat converter
The car uses fuel like crazy, probably somewhere between 300-350km per tank, but i have only gone through about a tank and a half in this time so i cant get a good average
I have noticed only in the last couple of drives that when i am driving on a flat road or on an incline that the minute i take my foot off the pedal the revs immediately drop to 1000 and then sit on around 1200rpm, it makes the car feel like it is engine braking meaning i have to keep my foot on the pedal to not lose a significant amount of speed almost straight away
i am a beginner when it comes to cars and engine maintenance so i am not sure where to even begin with the issues, i have checked fluids and they all seem normal but that is the extent of what i have done
i would appreciate any advice anyone can give me on what to do!! if it is gonna cost me a heap of money to fix then i will just sell the car and start again, so any advice of this nature will be even more helpful! I have read through page upon page of the forums but i can only seem to find posts that cover bits of my issues and not the whole lot, and also have read lots of different suggestions but i cant seem to find a common enough fix between them all..
thanks!!!
Edited by sakuratoge7
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
