Looking but not posting haha. I like the filter adaptor, but surely its easier to get a filter assembly that doesnt have the heat exchanger on it? (rb20 and some rb30 i believe). Regardless, it looks good, must be handy having access to good machinery to make stuff like that.
Cheers buddy, yeah could buy something like that but just money and a possibility it might not fit etc.. this way it cost me nothing except half hour and some scrap bar i had at work lol. Yeah i definatley couldnt've done half this car without working in the industry lol.
Well have fitted the oil spiggot and works a treat
Also if you remember i made a cardboard template of what i wanted for the coolant and power steering tank.
Well its now home for test firting
Once im happy i will cap them. The front is obviously coolant and has the sight glass and the back is power steering so that will just have a screw on lid with a pin in the middle that will have a line on it lol.
Also awhile ago had issues with overheating so sourced a ISC alloy rad and made an alloy thermofan holder
Havent had a chance to test it on the track but just warming it up and driving on the street as soon as i hit the switch it dropped 30* easily so should be alright
Funny to look at the fact that 6 months ago i had this...
Also it makes you appreciate what you have i used to be working in a gravel carport awhile ago and now i have progressed upto a nice single garage
Tight ass form of racking and my whiteboard with list of what needs to be done etc....
And the engine bay as it sits currently
Sorry for the long ass post just had 10 mins to chillout today hahaha
  • Like 1
Well trying to make some headway with this wiring. My plan is just to build the engine loom for now. I dont want to turn this into a bigger project than it already is. The provisions are there for a full engine and body loom but thats down the track.
Thats obviously the haltech mounted with fuse box and relays mounted and all getting wired up. Cant do much on the engine loom untill Intake manifold rocks up to run cables for injectors and CAS etc..
Gotta admit i do have a pretty amazing Fiance. Its too hard to wire everything up in the shed so she lets me setup in the lounge room to do all my soldering etc..
My amazing fiance and the helper :P
  • Like 1
Cheers guys, hopefully get some done on it this weekend. Already cut off the T2 flange and have mocked up the T3 flange so will tig that back on sunday and then can start doing oil and water lines.
Hopefully inlet manifold will be here soooooooooon so i can start doing injector wiring. Hopefully have some more pics sunday arvo guys
Also i have had a couple of people message me telling me that my oil cooler mount is all wrong and that you should have both the inlet and outlet up top. This is is a common miss-conception caused by the fact that most people mount theres this way. If you think about how a radiator is mounted you have your inlet at the top and your outlet at the bottom as the coolest oil will be at the bottom. So if you have your outlet at the top your still pushing hot oil back into the motor. Just found this
The reason you dont want the inlet and outlet at the bottom is because you will almost definatley just fill the cooler with air and then have the possibility of getting air into the system.
Got slightly side tracked today.... My tig just gets picked up an moved around the shed an its a pain in the ass with the bottle etc... coming home last night an someone has brought a trolley up my street lol... yepp that will do. post-96314-14342505616068_thumb.jpg
:D now have a nice little tig trolley
  • Like 1
Got slightly side tracked today.... My tig just gets picked up an moved around the shed an its a pain in the ass with the bottle etc... coming home last night an someone has brought a trolley up my street lol... yepp that will do. attachicon.gif1434250559143.jpg
Hahahahaha love it. Lets hope it makes for easier progress and more updates :)
Mainly wiring this weekend but did manage to get the new T3 flange welded onto the manifold. Also because im running LS2 coils i made some coil mounts that bolt upto the tocker covers.
As for the wiring made a mount for the isolator.
So now the starting box is pretty much complete. Has all headlights, indicators and wipers under the iso switch.
How do you bend up sheet metal when your too slack to go into work?
Clamp 5mm plate to your bench and bend away! Haha worked reasonably well.
So currently wiring up the coils with power, earth and switching wires etc..
  • Like 1
Hahaha sorry mate works been hectic and thats whats paying for the build lol. I got one of the Chinese FFP and it needs some love so have just been attacking all the ports and port matching and blending it all. But my biggest concern is the water outlet as there meant to be a "tollerence" fit and it was as loose as a goose so have drilled and tapped the manifold and machined the outlet
Will try get some more updates this week tho
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
