Well, it's clearly not a ball joint. A balljoint is a ball in a part-spherical socket. Ball joints permit rotation movement in more than one plane whilst preventing the two parts of the joint to move apart from each other. This thing is a tapered bearing. It allows rotational movement in 1 plane. The other planes are taken care of in the other joints in the suspension.
OP, have you have re-torqued it to make sure its not just loose?
The main bloke is going to have a look at it on Monday, he was not in when his bloke did the test ?
I wonder why a bloke that works on cars would not know this, he may not be the boss but are the Skyline GTRs so different if you have not worked on them before?
Spent a bit of time trying to get some info off the web yesterday, I must be asking the wrong questions ???????
just loose is pretty likely, it is one place you could pull the front suspension apart to remove and reinstall the engine (to clear the driveshaft)
Don't worry about what it is called, as long as they are talking about the right joint you are fine. If you pointed out to them that it only allows movement in 1 direction they would agree it can't be called a ball joint...
BTW these very rarely fail....they are hugely over engineered for their job.
  • Like 1
I am really starting to think they should have had the boss have a look, maybe it is not even this part that is give the play, be interesting to see what the Bossman has to say on Monday.
But if you do not have a name for the part , it is hard to order it. Kudos said it was , see below link
King Pin Bearing Kit (1 Side) - Nissan 300ZX Z32 & Skyline R32 GTR / GTS-4, R33 GTR / GTS-4 & R34 GTR
Seems like a reasonable description, I guess they are taking the responsibility that the part is correct.
If you want me to double check the part# send me your VIN# and I will check in FAST....I guess it will be the same Zeb posted above
Sent PM :)
You were driving it with both bearings stuffed, what was the steering like ?
You'd be surprised. You can have most of the bushes and bearings in the front end off a Skyline pretty well f**ked and barely notice anything apart from a few clunks.
Probably why did not notice it, thought it might have something to do with the way my car can tramline pretty hard at times..
Put the RD08Rs on and it seems a little better, well I will wait for another drive before I get carried away, haha
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
    • Welcome to SAU, looks like you've picked up a nice one! Any plans to spend more money that you have on it until you hate it?
    • Also I cut away the top metal that was bent as there's no way I could have gotten it level and the rust stopped. I can also see clean metal under the windscreen. So it looks like this is the extent of it. The lower metal here is also strong.
