Does anybody have feedback on the mace engineering manifold spacers? They are made from insulating material so may keep temp down too.. If you are searching for performance I dont think you will feel a difference after switching to the plazmaman (I didn't) but don't regret it because of the difference it makes in the engine bay. I can't comment on the greddy, but even spaced I don't think it would either
That would be good to know if anyone has used the mace engineering ones, I'm interested cause u can use those spacers with any plenum u decide to run as long as it's not that thick I don't think u would need to modify anything.
I gather u went from stock to plazmaman & didn't feel any gains..... Ive currently got the greddy & that's what started this whole thread, would it make much of a difference midrange torque/lag wise to run a spacer & would it pose any problems..... I know some guys have done it unfortunately none of them have commented (maybe they haven't read this or no longer active members).
I love the look for the greddy but now I am willing to switch to less pretty (in my opinion) plazmaman if there is noticable midrange gains to be had & so far that seems to be a resounding yes from everyone.
I had an r33 rb25 (rest well my faithful motor u will be back one day) but for now I'm buying a 25neo & not sure wether to do just Pistons & headgasket (maybe oil pump as I have billet gears sitting here) & put that back in (trying to keep costs down)!! Of course also doing the plazmaman plenum change over from the greddy & I'll see what the results look like I know it's not exactly a great comparison but it's better than nothing
I was very lucky to get a plazmaman plenum, TB, piping & bov at a very good price for my neo. I also have a 6boost mani ready - just need a turbo. Cant go wrong with plazmaman I reckon.
From memory 10-12 before you hit the fuse box.
I'm guessing that would be in a R34? That wouldn't make bugger all difference to the midrange. In a R33 you might have a bit more room but I think even at best 40mm wouldn't make much of a difference From what my mechanic says.
Seems like the plazmaman plenum is the best option out of the forward facing plenums! I need a bargain like Mrfijigold seems to have landed!
I might be selling my hks 3037s but we'll see ?
After I fit my Neo if I end up using the same turbo then I'll post my old dyno run vs my new. I know it's not a fair comparison but it's something. My old setup was an R33 rb25 with a greddy plenum my new setup (If i don't change turbos) will be a Neo with a plazmaman...... I'll post updates as they happen in the mean time anymore input on the original topics is appreciated ?
  • Like 1
I suppose a way of estimating gains based on runner length would be to look at cars or motorbikes which have variable length runners. Then you could tell If 6 mm or so is worthwhile. Im.guessing it's not, in order to get a decent gain it would be in the order of 100 mm
Looking forward to seeing how would go with the neo.
100mm is the correct order of magnitude to make noticeable changes. When adding trumpets onto ITBs or sidedraught carbies, you're talking about 50-150mm trumpets, and not being able to buttdyno tell the difference between say, 50 and 75mm. The real dyno might show you some numerical difference, and the car might be measurably faster/slower as a result, but the butt really couldn't tell.
Unfortunately our engine bays don't accomodate 100mm ? so it looks like the spacer idea for midrange is not a good thing to consider!
I'm thinking a thin spacer from mace engineering for heat soak purposes with a plazmaman plenum is a win win ?
Thinking I'll paint my plazmaman plenum same colour as my cam covers but I'm wondering wether I should paint the factory runners also or just have them cleaned up.......?
I am about to remove my plazmaman anyway and considering installing a mace spacer, but is it possible it might make the runners 'too long' and have some negative implications? Or did you decide an extra 6mm even on the standard runners wouldn't be enough for the 'bum dyno'
6mm wouldn't make any difference in a bad or good way really it's too small to change the characteristic of an engine but the heat soak benefits would be worth while I would think.... ? definitely let us know how u go!
All those style of plenums aren't the best for midrange torque or for better spool that's why I'm making the swap from greddy to plazmaman.... It's the design in the short runners that makes them like that.
if it's made for r33 rb25 it would fit on a neo without too much hassle! ??
  • Like 1
And I'm hoping somebody can comment on any intake temp changes using the mace insulating spacer
I think you & me need a megaphone or something lol! Definitely people out there who've done these mods probably just haven't been on in a while or not reading this topic...... Hhhhmmmmm *scratches non existent beard*
I use a phenolic intake gasket on the inlet manfold for my RB25DET. My inlet plenum uses the standard lower runners with a MX Performance plenum top (similar to a Plazmaman manifold).
I don't beleive the intake temp changes would be very significant, as the coolant runs through the inlet manifold. This will heat up the inlet manifold to what ever temperature the coolant is at. Conversly if you were running a standard gasket, the plenum may be a touch warmer, but the coolant will then do the opposite and try to bring the temperature of the inlet manifold down to the level of the coolant. So there's probably only a few degrees in it either way.
I would have preferred to use a phenolic gasket between the lower runners and the plenum top (provided it could seal correctly) however I wasn't able to find anyone who makes them.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
