Series 2 rs (rwd) SILVER
Wrecking
All parts available. Car is undamaged and registerable.
If not listed ask. If a price is no good let me know, I'm negotiable and reasonable person. I want to sell the stuff, butnot give it away!
RB25 Neo bottom end, 140,000ks excelllent condition $500
Rb25 neo head, modiifed for external vct feed for 2530 use. including oil line and tee piece, standard cams and covers, no vct pulley or cas $600
vct pulley with mod to allow adjustment and diallling in of cams $100
Alternator $75
Starter motor $75
AFM, worked great $60
Neo CAS $200
stock air box and snorkel $60 suit R34 also
idler and tensioner, less than 6000k's use $50
HKS return flow type r cooler kit. Flowed just over 300rwkw no worries. Has been dented into something, doesnt leak or affect performance. This is a full size core, with no cutting required at all. Including all clamps and joineres etc. Been painted black. Can spin around and not see dented bit so all good! $250 Also fit R34 GTT
Very nice sounding custom 3 inch dump back exhaust. Below legal noise, no drone!!!!! Hoooker aerochamber muffler and berklee straight through rear, flowed over 300rwkw no worries, fits nicely. 1/2 of it is stainless, all mandrel bent $400
Standard exhaust manifold $50
rb26 oil pump $80 great for rb2530 build
R33 standard turbo, great condittion $180
Fan with clutch,no cracks, worked well $55
Alluminium radiator , pretty thick , stock shroud fits on it. kept car temperature controlled perfect, $100
Air con compressor $75
Power steering pump $75
Series 2 tail lights, complete, perfect condition $250
Headlights $250
Grill, dodgy black paintjob, $50
High beam lights, (spotlights in the grill ) $150
Standard RS front rotors, good condition,no shudder etc. $75
Front calipers with pads clips etc $50
rear rotors $75
Rear calipers $55
RE4R01B standard valve body $75
Instrument cluster (dash) auto, just over 100,000 ks $125
Power window switch $75
climate control unit $65
Steerig wheel and airbag, good nic, $75
Clear side indicators, fit a bit loose but never fell out! $25
Tailgate $100
RS4S alloy wheels, rear tyres 1000k's use, Maxxis tyres, front more use but still heaps left , wheels in good condition, few small marks $400
HEAPS more, cant remember, ask me for a price or make an offer.
PICS Available, cant be bothered uploading heaps of pics for no reason, ask me if you need a pic.
Cheers
Ben
I'm after the passenger side sunshade if it's the same as an R34....Could you possibly post a pic? how does $15 plus post sound?
No worries. Not sure if the same or not.
Edited by Ben C34
Ok. Some of the prices I listed are a bit off the mark, so hit me with a sensible offer for what you need.
A lot already sold, will update what's left soon.
Cheers
thanks ben, but yeah it's a bit different. The mounting point is a different shape, so the bolt holes may be different. I'll try and find an r34 one.
cheers.
  • Like 1
You did an LS1 coil on head plug setup for your Stag, didn't you? If so, are you selling it?
Yes I did, and at this stage another guy is interested in a pack including nistune, z32, coils, sway bar, r34gtt brakes etc...
I will let you know if he doesn't come through with the cash.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
