Look at recent posts for updated list of remaining items.
Series 2 rs (rwd) SILVER
Wrecking
All parts available. Car is undamaged and registerable.
If not listed ask. If a price is no good let me know, I'm negotiable and reasonable person. I want to sell the stuff, butnot give it away!
RB25 Neo bottom end, 140,000ks excelllent condition $500
Rb25 neo head, modiifed for external vct feed for 2530 use. including oil line and tee piece, standard cams and covers, no vct pulley or cas $600
vct pulley with mod to allow adjustment and diallling in of cams $100
Alternator $75
Starter motor $75
AFM, worked great $60
Neo CAS $200
stock air box and snorkel $60 suit R34 also
idler and tensioner, less than 6000k's use $50
HKS return flow type r cooler kit. Flowed just over 300rwkw no worries. Has been dented into something, doesnt leak or affect performance. This is a full size core, with no cutting required at all. Including all clamps and joineres etc. Been painted black. Can spin around and not see dented bit so all good! $250 Also fit R34 GTT
Very nice sounding custom 3 inch dump back exhaust. Below legal noise, no drone!!!!! Hoooker aerochamber muffler and berklee straight through rear, flowed over 300rwkw no worries, fits nicely. 1/2 of it is stainless, all mandrel bent $400
Standard exhaust manifold $50
rb26 oil pump $80 great for rb2530 build
R33 standard turbo, great condittion $180
Fan with clutch,no cracks, worked well $55
Alluminium radiator , pretty thick , stock shroud fits on it. kept car temperature controlled perfect, $100
Air con compressor $75
Power steering pump $75
Series 2 tail lights, complete, perfect condition $250
Headlights $250
Grill, dodgy black paintjob, $50
High beam lights, (spotlights in the grill ) $150
Standard RS front rotors, good condition,no shudder etc. $75
Front calipers with pads clips etc $50
rear rotors $75
Rear calipers $55
RE4R01B standard valve body $75
Instrument cluster (dash) auto, just over 100,000 ks $125
Power window switch $75
climate control unit $65
Steerig wheel and airbag, good nic, $75
Clear side indicators, fit a bit loose but never fell out! $25
Tailgate $100
RS4S alloy wheels, rear tyres 1000k's use, Maxxis tyres, front more use but still heaps left , wheels in good condition, few small marks $400
HEAPS more, cant remember, ask me for a price or make an offer.
PICS Available, cant be bothered uploading heaps of pics for no reason, ask me if you need a pic.
Cheers
Ben
  • Replies 57
What size and offset are rims
17 . That's all I know.
Stock rs4s rims, might check tommorow otherwise Google it ...
Cheers.
Ben
Does the radiator have the transmission stuff in the lower tank?
Is the steering wheel tiptronic or manual?
Edited by Race__24
Sort of. One of the fitting is stripped. I wouldn't run the trans fluid through the rad anyway. You are best off with a decent trans cooler. The rad loop is more a warmer than a cooler anyway.
Best setup is a huge trans cooler with a thermostat and fan. Even then depending on where you live most aussie places the thermostat isn't required.
Steering wheel gone.
Lots gone.
Pretty much just engine stuff left. Well that's not true, still got headlights taillights grill etc.
Pretty negotiable.
Depending on if a previously interested guy actually buys stuff I will have whiteline rear sway bar, nistune with licence and cable, z32, id725 injectors, fuel pump and cradle and modified lid, r34 gtt brakes new rotors and pads, and subframe lock kit
Edited by Ben C34
Do you have an uncut reo? Are they the same as s1?
How much for the Nistune?
No uncut reo. Not sure if different or not
At this stage the nistune is likely sold, but if not I'll be in touch.
I'm not 100% that it would be any use to me anyway, I'll need to wire it in parallel to the s1 ecu to keep the box working. I'll have to talk to some people.
Yep. I should have realised yours was s1 based on the reo question!
Silly autos. They really screw things up.
I'm not sure what would need to be swapped to make it work. I wonder if whole box from s2 would do it (also have one, with servo and shift kit)
Otherwise if I was you i would just go full manual valve body and use whatever ecu.
If I was to go manual I'd just go full manual conversion. I'm going to talk to the guys at mv automatics and see what it actually needs to shift.
  • 3 weeks later...
Have you got the rear bumper bar?? Would this fit a S1. Price??
Cheers Shane
Rear bar gone.
Not sure if it would have fitted.
Hey Ben do you have auto transmission? Cheers
Yes, it might be sold though.
Only suit rwd either stagea or r34.
With MV shift kit and billet second gear servo.
Will let you know if the other guy bails.
Cheers
Ben
Hey after passenger visor, rear cup holder, rear boot handle cup and centre dash pocket and bonnet struts too.
Also still have the climate controller? Is it a single din or the large sat nav thing
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
