Look at recent posts for updated list of remaining items.
Series 2 rs (rwd) SILVER
Wrecking
All parts available. Car is undamaged and registerable.
If not listed ask. If a price is no good let me know, I'm negotiable and reasonable person. I want to sell the stuff, butnot give it away!
RB25 Neo bottom end, 140,000ks excelllent condition $500
Rb25 neo head, modiifed for external vct feed for 2530 use. including oil line and tee piece, standard cams and covers, no vct pulley or cas $600
vct pulley with mod to allow adjustment and diallling in of cams $100
Alternator $75
Starter motor $75
AFM, worked great $60
Neo CAS $200
stock air box and snorkel $60 suit R34 also
idler and tensioner, less than 6000k's use $50
HKS return flow type r cooler kit. Flowed just over 300rwkw no worries. Has been dented into something, doesnt leak or affect performance. This is a full size core, with no cutting required at all. Including all clamps and joineres etc. Been painted black. Can spin around and not see dented bit so all good! $250 Also fit R34 GTT
Very nice sounding custom 3 inch dump back exhaust. Below legal noise, no drone!!!!! Hoooker aerochamber muffler and berklee straight through rear, flowed over 300rwkw no worries, fits nicely. 1/2 of it is stainless, all mandrel bent $400
Standard exhaust manifold $50
rb26 oil pump $80 great for rb2530 build
R33 standard turbo, great condittion $180
Fan with clutch,no cracks, worked well $55
Alluminium radiator , pretty thick , stock shroud fits on it. kept car temperature controlled perfect, $100
Air con compressor $75
Power steering pump $75
Series 2 tail lights, complete, perfect condition $250
Headlights $250
Grill, dodgy black paintjob, $50
High beam lights, (spotlights in the grill ) $150
Standard RS front rotors, good condition,no shudder etc. $75
Front calipers with pads clips etc $50
rear rotors $75
Rear calipers $55
RE4R01B standard valve body $75
Instrument cluster (dash) auto, just over 100,000 ks $125
Power window switch $75
climate control unit $65
Steerig wheel and airbag, good nic, $75
Clear side indicators, fit a bit loose but never fell out! $25
Tailgate $100
RS4S alloy wheels, rear tyres 1000k's use, Maxxis tyres, front more use but still heaps left , wheels in good condition, few small marks $400
HEAPS more, cant remember, ask me for a price or make an offer.
PICS Available, cant be bothered uploading heaps of pics for no reason, ask me if you need a pic.
Cheers
Ben
  • Replies 57
What size and offset are rims
17 . That's all I know.
Stock rs4s rims, might check tommorow otherwise Google it ...
Cheers.
Ben
Does the radiator have the transmission stuff in the lower tank?
Is the steering wheel tiptronic or manual?
Edited by Race__24
Sort of. One of the fitting is stripped. I wouldn't run the trans fluid through the rad anyway. You are best off with a decent trans cooler. The rad loop is more a warmer than a cooler anyway.
Best setup is a huge trans cooler with a thermostat and fan. Even then depending on where you live most aussie places the thermostat isn't required.
Steering wheel gone.
Lots gone.
Pretty much just engine stuff left. Well that's not true, still got headlights taillights grill etc.
Pretty negotiable.
Depending on if a previously interested guy actually buys stuff I will have whiteline rear sway bar, nistune with licence and cable, z32, id725 injectors, fuel pump and cradle and modified lid, r34 gtt brakes new rotors and pads, and subframe lock kit
Edited by Ben C34
Do you have an uncut reo? Are they the same as s1?
How much for the Nistune?
No uncut reo. Not sure if different or not
At this stage the nistune is likely sold, but if not I'll be in touch.
I'm not 100% that it would be any use to me anyway, I'll need to wire it in parallel to the s1 ecu to keep the box working. I'll have to talk to some people.
Yep. I should have realised yours was s1 based on the reo question!
Silly autos. They really screw things up.
I'm not sure what would need to be swapped to make it work. I wonder if whole box from s2 would do it (also have one, with servo and shift kit)
Otherwise if I was you i would just go full manual valve body and use whatever ecu.
If I was to go manual I'd just go full manual conversion. I'm going to talk to the guys at mv automatics and see what it actually needs to shift.
  • 3 weeks later...
Have you got the rear bumper bar?? Would this fit a S1. Price??
Cheers Shane
Rear bar gone.
Not sure if it would have fitted.
Hey Ben do you have auto transmission? Cheers
Yes, it might be sold though.
Only suit rwd either stagea or r34.
With MV shift kit and billet second gear servo.
Will let you know if the other guy bails.
Cheers
Ben
Hey after passenger visor, rear cup holder, rear boot handle cup and centre dash pocket and bonnet struts too.
Also still have the climate controller? Is it a single din or the large sat nav thing
    • Nothing wears "the most". Different cars will always show signs in a different place. 114000 km is either nothing at all (as in, given the calendar age, nearly brand new) or it's completely unbelievable. We stopped believing numbers like that about 15 years ago. Having said that, my car is up around 270000 km and I have put bushes into some places** as many as 10 times in >25 years that I've owned it. ** FUCAs, which are different on an R32 than on a 33, so not likely to be the same issue for you. I have original ball joints all the way around. They are perfectly fine. Same with the spindle bearings in the front. Tie rod ends have all been done at least once though. Pretty much every other bush in the car has been done at least twice. Some of those in the first 100000km after I got it (which was at a genuine 23000!). Some of those bushes are now sphericals, and they are on a <cough> regular maintenance schedule, hence why my FUCAs have been rebuilt so many times. Half of those 10 in the count above would be in the last few years! 'twere I you, I would budget on replacing everything, for fun and prevention. If they really are 30 year old rubber, they will all be unpleasantly aged in one way or another. Whether that's corrosion of shells, or the rubber cracking, or sagging under the load, etc etc.
    • Tighten until it starts to get loose again, then back off 1/4 turn?
    • Do them as you'll find when you remove them they are perished/dried.    Its probably one of the best things to do as makes the car so much more responsive. Do ball joints while there too.
    • Hi All Got an R33, about 114,000km on the clock.  Handles very nice, no signs of issues.    Engine is out and i'm doing an underbody refresh, mainly painting subframe, cosmetics etc. Can't see anything physically giving play, but I'm wondering which bushes are the ones that wear the most, or the first ones that may give problems down the track? For good measure I'm thinking to fit new ones. Thanks
