Hi all,
In the past I've had the 31, 32, 33 and 34 Skylines (GX, Gtst, Gtst S2 and GTT), now its come the time to buy a GTR.
I could get the 32 and 33 however being almost 2m the cars are way too small for me (I was smaller when i had the other versions).
Now i know the 34gtr will still be a tight fit, but ill also make sure to extend/replace the rails that are OEM on the car so the car is comfty on those weekend drives.
Bascially speaking when i buy it, it will be kept until the last of my days.
What I wanted to know is - what is a better option to go with GTR, VSpec 1 or 2?
I know what the general differneces are of each model, but if you were in the situation would you just buy a nice clean example of a VSpec1 and give it some TLC? or get the basic model and upgrade the brakes and put the diffusers in?
Im looking to spend about $50k so any advice of some experiences owners would be great.
Thanks all
https://www.sau.com.au/forums/topic/452103-importing-a-r34-gtr/
I'd go vspec2 if you can find one for that price in good cond. But if you can't find a clean vspec i'd look at the normal gtrs.
If I was you i'd rather have an immaculate gtr than a destroyed vspec2. but you can always fix issues up as well.
But by the sounds of it, you're more experience than me. You'd know more.
With a budget of $50,000 Milan you are already at the upper or upper-middle end of what V-Spec BNR34s are going for now.
So ignoring the idea that you might ferret a budget for modifying, I'd go for the V-Spec.
The V-Spec II at the lower end of the spectrum might go for about $58,000 and up.
The hard time to sell is now, so you might be lucky.
If you're prepared to wait a few months after buying one in Japan at auction, you might be able to squeeze a good V-Spec II within your budget.
Y4,000,000 + AUD$10,000 for exporter/freight/freight insurance/port storage/importer/Aust Gov't/compliancing/registration
  • Like 1
Always bringing sound advice with facts & numbers to back it up. Kudos to you Terry!
A V-Spec is what I would choose & if the budget allowed, the next choice would be a Nur..
Milan, all the best in your search for a BNR34 :)
Thanks for the reply guys.
From what I can tell the extra $ you are paying for the Vspec 2, its better to spend on the Vspec 1 and make the furthrer changes you want - brakes/disks and cosmetics.
Im in talks in J-Spec (Im located in SE Melb and if you have any other reputable importers im more then happy to talk to) about importing a nice model I dont mind the wait or if the car has done some mileage as it will be a weekend car to be worked on and driven not much else. I've imported a Nissan Lauren C33 from NZ (family car we owned since it had 101kms o the clock, until it finallly died at 309,000kms.....amazing car) and unless you know the process or the right people it was a head case. So im after an importer that knows what they are doing and will finalise the docks-registration phase.
Some of the immediate mods are bigger radiator, bigger oil cooler (not sure if its needed but always good to have for those hot days) discs/brakes and good old service. Then down the line maybe some more performance based stuff - but thats down the line.
I could push the budget to $60k, however I wanted the max to be about the 40-50k mark and have ample funds spare for some mods. Thanks again all - apprecaite it.
I would seriously buy one with the best chasis you can, forget the model.
A clean car chasis is getting harder to find.
As for the models:
GTR: Lightest car with mechanical diffs
VSpec: Front and rear diffuser
V-Spec ii: Black interior and carbon bonnet
Australians have this obsession with v-specs.... they arent better, only car that is significantly better from factory is a nur.
Also look at something that has mods already (will save you a MASSIVE amount), and be prepared to rebuild at some point (15k for the motor).
Edited by sinistaGTR
  • 1 month later...
I've been in contact with some importing businesses and a few individuals on their 34 GTR's and taking into consideration my financial status - its easier for me to buy a 33 gtr and spend the extra money on the mods.
34 - will be around $50,000 if I'm lucky, where as the 33's can be picked up from 25-35k and can spend the rest of some mods.
Any thoughts?
