Hi Guys,
I've been long pondering the idea of converting my factory CAS based ignition system to a trigger wheel configuration. Upon much investigation's I found that there are 2-3 kits on the market for the RB engine series that range from the basic setup to the extreme where everything in included which in some cases is much overkill.
I decided to design my own setup, Having a 3d printer and CNC mill at home I thought how hard could it be - Really. I spent a few hours in CAD drawing up what I would expect to work with my RB20 and a factory CAM gear.
Crank Bracket:
Cam Bracket:
From here I set to work printing them out and dummy fitting the sensors to check my measurements
Crank Sensor Mount: (Sorry only v1 image but you get the idea)
Cam Sensor Mount:
With a few adjustments everything lined up perfectly!
The moment of truth arrived and I set to creating the tool paths to cut the parts from aluminium on the mill at home. I've thus far only made the final crank sensor mount.
After the above was machined I then set to modify the factory rb26 balancer as the trigger:
Once machined I mounted the balancer back to the engine and confirmed fitment of the mount and sensor
So this is the progress so far of my Christmas break with a week 1 week down and another to go I hope to have the trigger finger for the cam gear sorted in the next day or so and will post my progress.
If anyone would like a copy of the CAD files please PM me I am happy to hand them out and once everything is sorted hope to be able to offer these to people who don't have access to have these machined for roughly $250 a set
Your feedback is welcomed!
Regards
Cameron
  • Like 1
https://www.sau.com.au/forums/topic/452152-open-source-rb-trigger-kit/
I would be very keen for a setup to suit rb25 neo,.. What else would be required? Just the Hall effects sensors?
I am trying to understand the advantage of this. Would I be correct in saying the rb engines do not have a crank sensor and rely on cam sensor to determine crank position? If this is correct then why do additional cam sensors also need to be installed?
Running the timing off the CAS can be a very inaccurate way of controling your timing.
CAS runs off the exhaust camshaft, which is driven by the timing belt, the belt can stretch, slap and so on making the timing move around.
Best way to run it is straight off the crank, bypassing the inaccuracy or the timing belt and the issues it causes to timing fluctuation.
Ok thankyou, why does the cam sensor also need to be changed if it is already fitted with one from factory?
Just to expand on what Ben said, the original Nissan CAS is too complicated for the task of just providing the stroke reference once you've handed the task of overall engine position over to a sensor on the crank. So you bin it and its slightly flaky optical triggers, replacing with a nice single sensor.
Thanks guys for all the feedback overnight and PM's.
The reason for not going for 12 trigger points is some ECU's cannot keep up with the count, Yes I know with less if the count is lost it takes longer to regain the position however with only 6 points their is alot less chance of losing the count as the ecu can keep up.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
