I plan on testing the balance of the balancer however with the same amount of material being removed on all sides it should not too be much out of the original balance.
I would be interested in the results from this, modifying the factory balancer could save $700+
I have the ross 32-2 teeth setup with the standard CAS for phasing
There are plenty of kits floating around the world ATM, but it is always good to see someone else's approach to this issue
You just use the input that would normally read the crank angle output from the factory CAS, it just has to be programable
Are you saying the factory cas can be retained and the signal just has to be modified so it can be interpreted?
I'm not sold on the design of the cam trigger finger, but everything else looks great
Edited by BlackBox
I'll let you know once i've found someone to balance it for me.
The factory CAS could be used in theory just as a reference. The factory CAS disk has 360 outer slots and from memory a single inner ring for the reference.
Me either at this stage. I'm happy with just using a steel bolt on the adjustable CAM gear however I thought people would like something universal without the need for a aftermarket cam gear however I guess in the scheme of things having to spend $300 on a pair of gears isn't a bit deal.
Nah I didn't have to touch the stock Cas just pick up the crank signal at the ECU plug and run a new wire to the crank trigger then change the settings in the cam/phase settings to read the 6 different sized slots in the ECU, it has an event counter it phases from
The new design cam wheel looks heaps better
  • Like 1
Thats what always had me wondering why people were putting a new sensor on the cam, factory one already has it for cam position phasing, just dont use the signal from the 360 outer slots and run a wire like you did from the crank trigger.
Makes life so much simpler.
If somebody could describe how to do this in a bit more detail I would be extremely appreciative, (pm if necessary don't want to deviate too much more)
The FC can't do this, I would be a little suprised if even the top Haltech could do it, interested to know if it can for sure
Easiest way with the FC is get a 36-2 trigger wheel with the missing teeth @ 85deg after TDC and the convertor box from Ross to convert the trigger wheel signal to what the FC will read, can also be used with stock and Nistune ECUs
That makes no sense
The ECU only works as well as the hard wear giving it reference
I understand that but I have read many posts sayin that it's a problem only with the newer ECU, because of the optical sensor and the speed of the new ecu's..
The concencus of the recent discussion (in another thread not far from here) was that older, slower ECUs are not seeeing (all) the timing fluctuations that the newer faster ones are. There may be some placebo involved iin that findiing, because the comparisons may not be sufficiently scientific (ie, same car, same timing belt, same CAS, just the ECU changed). But it is distinctly possible that it is true.
  • Like 1
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
