Batch 1 has been ordered and paid for with the Factory and product time is 25 days so now the wait starts.
Thank you for all the local guys who commited and the fellows from Canada and the USA - You got a bargain with the Exchange rate! Should of charged you double.
Oh well not in it to make money:)
Ok well the car is back from a fresh coat of paint and looking smick!
Well now back to the project, All fitted up ready for the harness to be matched up from the OEM CAS wiring.
post-23119-0-30786700-1430626968_thumb.jpg post-23119-0-88659300-1430626970_thumb.jpg
post-23119-0-37346800-1430626973_thumb.jpg post-23119-0-53413900-1430626975_thumb.jpg
News from the Factory puts the first batch about 2 and a bit weeks away...
  • Like 3
Car looks awesome so do the parts!
They are still due to be shipped on the 25th From the Factory as planned. I spoke to the Factory Saturday evening and production has started and they will be out for finishing around Wednesday.
Guys,
I have two sets coming without being spoken for. IF your interested let me know and I'll put you on the list.
Final lot of parts off to be finished in Black.
Dads Birthday pressie also made just for a bit of fun for a small steam engine
Edited by murrayis
Hey Guys,
Slight Delay in shipment due to there being a flaw in the finish of one of the items. I've chosen to have it refinished rather than shipping a defective product. I hope you can understand.
The factory has said they will have the parts back tonight and will provide pictures on the finished products before shipping tomorrow
Thanks for your understanding.
Guys
Shipping has been arranged and awaiting confirmation of pickup. Tracking numbers will be dispatched in 2-3 days once they reach the Forwarder.
Everyone will get an email with these details asap.
Cheers
Cameron
Edited by murrayis
Morning all,
Batch 1 is now official and has arrived! I've just unpacked the Aussie stock to ship out later today and I could not be happier with the result.
I hope everyone is happy with their product once it arrives!
post-23119-0-55144800-1433122139_thumb.jpg post-23119-0-10481200-1433122142_thumb.jpg post-23119-0-06661100-1433122145_thumb.jpg
post-23119-0-48867900-1433122146_thumb.jpg post-23119-0-91522300-1433122147_thumb.jpg post-23119-0-39728500-1433122149_thumb.jpg
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
