You must use 12 teeth on the crank if you want this setup to work with your Haltech Platinum Pro. :)
FYI this is 100% true. I called Haltech.
Also in regards to the Haltech Platinum Pro Series on an RB26:
You can use the "24 + 1" drop down option to:
1) Use Murrayis' cam angle sensor and honeywell hall trigger as the HOME sensor (the '1' in the "24 + 1")
2) Use 12 teeth on the crank with the honeywell sensor. IF YOU USE A WHEEL ON THE CRANK-You must use Hall-effect trigger or VR (reluctor) trigger!! (this is fine since this particular kit is designed around the honeywheel HALL trigger).
I hate to say in this particular thread...but all this being said, you can use the factory CAS with the AEM 24+1 trigger wheel in it for the CAMSHAFT "HOME" location and Murrayis' CRANKSHAFT sensor with a 12 tooth pickup for the "24" sensor. This would still give you the resolution you need on the crankshaft and appear stock on the camshaft (ie- not cut up any covers).
Thanks
Patrick
Hi Patrick,
When I was checking with Haltech originally they said 6 slots on the balancer would be fine as the crank does two rotations per cycle making 12 trigger points or 2 per cyl.
This is true for any universal Haltech ECU such as a Platinum Sport or Elite, but not the Platinum Pro Plugin series ECUs. The Pro only supports the stock setup or 24+1 as explained above.
For the single cam home/sync signal, in the past I've just covered the stock disk with a sticker and cut out one of the inner 6 windows to make a single slot for the optical sensor to pick up. Works fine.
  • Like 1
Simple genius there! Would save all several bucks on the home trigger.
  • 3 weeks later...
  • 1 month later...
anyone got this with nistune?
Im thinking of getting the crank version instead of the cam so i dont have to worry about belt slack.
Nope makes no difference the only thing to check is the signal voltage, you just have to make sure you use the correct signal wire off the cas if you want to use the factory loom and the other wire off the cas for your tdc cam trigger. That's it and done
OK helpful advice coming down the pipe.
About the Cam wheel and trigger:
1) The flat head cap screws that the trigger is apparently designed for are near impossible to find. I will be making some myself by machining normal M7 cap screws. The cams have M7x1.00 pitch threads...yes M7x1.00. Should have known when I had to get the 11mm socket out that something was funny. With my Tomei cam gears (and Tomei cams) I needed 43mm of depth for a NORMAL headed bolt to go on. a flat head screws should be similar length...Flat head cap screws are a great idea though because the countersinking will allow more room under the top timing cover (I'll get to that in #3 below). I have attached a picture showing NORMAL BOLTS M7x1.00 (50mm cut down to 43mm length). I also am using the factory plate and added lock washers.
2) Be Prepared to cut your timing cover. Thank goodness I had this gaudy Nitto clear cover and it trimmed out very easily. The sensor still SLIGHTLY protrudes into the flat plane of the cover, but I bet I could lightly file it (1/8" or so). I will be making a new plate to rivet on to my Nitto cover in the shape of the (sorry to say) Alien-head-shaped hole. Again see pictures for clarification. Not much about the design could be changed to rectify this.
3) The bolts from #1 above will definitely break the plane unless I find some flat head (countersunk) M7x1.00 cap screws. I'm telling you they are impossible to find...I'll be making some.
just after some clarrification on this,
why are the countersunk bolts required for the trigger wheel?i understand how they could give more clearance to the timing cover but what do you mean by break the plane? the plane of the timing cover?
and the cover would definitely need to be cut to clear the sensor? if thats the case i hope there is a work around..
has anybody got this fully fitted up and functioning?
Anyone used the crank trigger mount with a ross balancer? I have a metal jacket so i was wondering if I could use the bracket with the ross balancer, they should sit roughly in the same position and i might get the chopper wheel made for it as ross wants $340 and i dont think it should be that much to have a piece of steel laser cut to the size i need.
Yes the bolt heads would protrude into the factory timing cover. I will try to get some pictures next time I am at the shop, but I'm going hunting for a week, so it will be a while.
The parts he made are for countersunk bolt heads...but 7mm countersunk hex bolts are extremely hard to find.
Hi Guys,
Sorry I've been a little busy of late.
The M7 Countersunk bolts are hard to fine however not impossible - If you cannot locate you can use a spring washer and normal M7 cap bolt in it's place which will hold it securely.
I have this kit running on my car so it works with no effort what so ever once you've plugged in the tooth and TDC offset into the ECU.
You will need to cut your cover or leave it off all together. I've had my cover off for year without any dramas.
Oh k, but even with the correct bolts the sensor still protrudes and requires the cover to be cut?
Yes this is the case as well...only where the sensor is (I believe). I will try to dig around for pictures or get more for clarity for all. I've been down in the dumps lately...this car simply CAN NOT be finished!!! But this will give me some nick-nack issues to work on while I wait yet again for more parts from overseas (the last package was totally lost by international shipper).
Hi Guys,
Hi Cameron
Is there any difference in what the sensor reads with these two types of wheels? not being about 6 vs 12 points but in yours having it cut out compared to this chopper wheel having points, just wanting some ideas before I get something made up.
Cheers
  • 1 month later...
Has any solution been found for the trigger mount bolts or a work around for cutting the cover?
What is the opinion of getting the harmonic balancer balanced after machining slots in it? I have got 12 slots machined in my balancer but it has not been balanced.
Hi Jamie,
Most people are just leaving the top cover off or cutting the clearance out for the sensor to clear the cover.
As for the bolts - If you have not been able to find them then you can use a spring washer in the hole with a bolt as normal.
Guys & Gals,
I have one set of mounts left from a buyer who fell through. $400 delivered for the set if you are interested, I have them on my desk so can ship straight away with no delays.
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
