also selling my kit as i didn't want to remove my ross balancer.
Cameron have you finished with this project or are going to try and design another kit?
has anyone thought about using factory cas for start position then something off the crank or flywheel>
Hi Robert,
At this stage I am done with the kit however if anyone is wanting custom changes etc. I am happy to work with them to produce one offs etc.
I do not at this time have room for different blocks and rotating assemblies to work on different designs.
  • 5 weeks later...
  • 4 weeks later...
Long time, no reply and I'm sure this will likely only help a few people but here is what I did to solve the tomei oil pump interference and smaller diameter fluidampr issue. Modified Murrayis's mount, rotated the mount, added a cylindrical spacer, tapped the actual sensor and I'll be cutting notches in my crank balancer. I'm going to go with (12x) .300" wide x .300" long and about .100" deep. The sensor is based on changes in magnetic field and should still pick them up even though the notches won't be totally through. Range on the sensor is .018-.080" inch. My .100" or so shouldn't affect it. I don't want to have a belt have the chance of getting freyed on notches.
LOL...exactly. Trust me I felt bad grinding and chopping on such a nicely machined part, but hey it's working and feels totally solid. And I left my spacer short so I can shim under it and move the sensor closer to the crank pulley if needed after I really torque it on the crank.
  • 7 months later...
Hey guys just got my car tuned at horsepower solutions and wanted to share my results from this trigger kit. Brief description is its a r32 with fully built 2630 running a forced performance super 94 with all supporting mods. I used a ross balancer and trigger wheel with murrayis kit. Worked a treat with only thing to do is space it apart with shims. Below are some pics
On 04/12/2015 at 9:36 PM, BlackBox said:
Hmm I really want to come up with a solution that doesn't require a gaping hole in the cover...
You can always just change to a custom made single window disc for the existing CAS instead of the the Murrayis cam trigger, that's what I'm doing.
I've already got the kit and got my balancer machined and re-balanced.. I am going to get a timing cover 3d printed to suit what I need
The last one I got was about $80, but that was for a CA18. Autronic sell them so do NZ efi. Just don't connect the REF to the ECU and use the Sync off the exhaust cam.
http://www.nzefi.com/product/24-tooth-cam-angle-sensor-disk-nissan-sr20det-rwd/
Maybe Matt could write different code for the CAS.  The Nissan one is providing 360 degree slots plus the 5 or 6 on the other circle.  The code might be easily enough altered to expect an arbitrary number of pulses on either of those.  Or maybe it would be a horrible exercise.  I'm not too au fait with decompiling the code out of (anything really) these ECUs.
  • 1 month later...
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
