Thanks guys for all the feedback overnight and PM's.
The reason for not going for 12 trigger points is some ECU's cannot keep up with the count, Yes I know with less if the count is lost it takes longer to regain the position however with only 6 points their is alot less chance of losing the count as the ecu can keep up.
Link G4 keeps up with 32
pretty impressive and informative - ta
Would be interested for RB26.
Having not looked into or thought about this, prior to this thread, is there any aftermarket kits available/recommended?
I'd like to support "murrayis" if made available for the RB26.
Ross do a crank trigger kit for RBs,
Includes balancer, sensor and trigger wheel..
Just need an available input for the ecu
I've got one, just need to make sure the sensor is positioned correctly
Thanks Joey
I'm sure I have read where a few peeps have gone the Ross Blancer and trigger and had issues.
Not blaming Ross as it maybe how it's set up. (throwing belts?)
Could be totally off the mark too :/
Yea Once I have everything sorted I'll do up a group buy. I've secured some machining prices from China... yes I know but it comes down to cost and have ordered some samples to check quality.
I've just started machining my set because I am impatient and it doesn't cost me anything :)
About 10 minutes in with close to 2 hours to go:
More progress pics to come.
theres a few around, one kit in qld(ONO 747 vl runs one)pics on this forum somewhere, one in vic(sticks sell them) and one in s.a just finished,
(pro gtr motorsport) plus ross,theres probally , no doubt theres others i don't know about
cheers
darren
Edited by jet_r31
The idea around my items is to be affordable for the DIY'er who can work around mounting them him/her self. The kit should work fine on all the dual cam RB series - As I only have a rb20 and a rb25 to test on this will confirm but I don't see many potential issues as they all use the same oil pump and cam gear sizes.
Thanks Joey
Yep I've heard of people throwing belts, I was making over 420rwkw and I only threw a belt once in over 10,000km of driving. Maybe installation issues? Not sure
Looks really good.
Ross one seems so expensive and ive never had an issue so never really considered it. This looks like it has a lot of potential. I could probably get the ross trigger wheel seen as I already have the balancer
Must be nice having that gear at your disposal. Id love to be able to make a CAD drawing and then just make it happen lol
It is great having toys to mess with to make little things that you can;t just buy. I converted my Mill to cnc over the past year and these are really the only full thing I have completed so far for a purpose.
Finally finished the Cam bracket just a little time ago. Didn't run through the finishing passes as these are just for me so the finish is rough :)
post-23119-0-98593900-1419921796_thumb.jpg post-23119-0-36655000-1419921799_thumb.jpg
I have the ross 32-2 teeth setup with the standard CAS for phasing
There are plenty of kits floating around the world ATM, but it is always good to see someone else's approach to this issue
You just use the input that would normally read the crank angle output from the factory CAS, it just has to be programable
I have thrown 3 Gates belts so far the last of which lasted less then 2 hours, fitted it drove to dyno then it couldn't take the power and decided to spread it self around the engine bay, I then had to drive the bastard home with no PS on 275/35/19 front tyres :(
Funny thing is I stopped at Autopro on my way home from work to get another belt or three but they only had there own elcheapo belt in that size and I needed to turn the car around so I grabbed it got home fitted it then went and got three Gates belts, well one full trackday and a spirited drive up putty and back plus a few thousand Ks later the elcheapo belt is still on there in perfect nick :/
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
