I plan on testing the balance of the balancer however with the same amount of material being removed on all sides it should not too be much out of the original balance.
I would be interested in the results from this, modifying the factory balancer could save $700+
I have the ross 32-2 teeth setup with the standard CAS for phasing
There are plenty of kits floating around the world ATM, but it is always good to see someone else's approach to this issue
You just use the input that would normally read the crank angle output from the factory CAS, it just has to be programable
Are you saying the factory cas can be retained and the signal just has to be modified so it can be interpreted?
I'm not sold on the design of the cam trigger finger, but everything else looks great
Edited by BlackBox
I'll let you know once i've found someone to balance it for me.
The factory CAS could be used in theory just as a reference. The factory CAS disk has 360 outer slots and from memory a single inner ring for the reference.
Me either at this stage. I'm happy with just using a steel bolt on the adjustable CAM gear however I thought people would like something universal without the need for a aftermarket cam gear however I guess in the scheme of things having to spend $300 on a pair of gears isn't a bit deal.
Nah I didn't have to touch the stock Cas just pick up the crank signal at the ECU plug and run a new wire to the crank trigger then change the settings in the cam/phase settings to read the 6 different sized slots in the ECU, it has an event counter it phases from
The new design cam wheel looks heaps better
  • Like 1
Thats what always had me wondering why people were putting a new sensor on the cam, factory one already has it for cam position phasing, just dont use the signal from the 360 outer slots and run a wire like you did from the crank trigger.
Makes life so much simpler.
If somebody could describe how to do this in a bit more detail I would be extremely appreciative, (pm if necessary don't want to deviate too much more)
The FC can't do this, I would be a little suprised if even the top Haltech could do it, interested to know if it can for sure
Easiest way with the FC is get a 36-2 trigger wheel with the missing teeth @ 85deg after TDC and the convertor box from Ross to convert the trigger wheel signal to what the FC will read, can also be used with stock and Nistune ECUs
That makes no sense
The ECU only works as well as the hard wear giving it reference
I understand that but I have read many posts sayin that it's a problem only with the newer ECU, because of the optical sensor and the speed of the new ecu's..
The concencus of the recent discussion (in another thread not far from here) was that older, slower ECUs are not seeeing (all) the timing fluctuations that the newer faster ones are. There may be some placebo involved iin that findiing, because the comparisons may not be sufficiently scientific (ie, same car, same timing belt, same CAS, just the ECU changed). But it is distinctly possible that it is true.
  • Like 1
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
