I plan on scraping the PFC for a new ECU anyway.. I thought the PFC had no issues with timing fluctuations anyway, and it was just the newer ecu's
my car:
pfc, stock belt, ati balancer, big cams. see the bottom plot. that's too much timing scatter for my liking.
Edited by black bnr32
I still think its the optical pickups in the cas that are the problems, because even with a 24/1 aem trigger disc i still saw issues, when we hacked up the cas with a hall effect pick up with 24/1 set up, had no problem.
It could well be. The optical slots are very narrow and they whizz past the sensor pretty bloody quick. I would have thought that diffraction effects might become apparent with such small openings. The apparent effect of different timing belts might compound the problem. Add in a few extra harmonics from a belt that does something different to what Nissan used and maybe some scary shit starts to happen.
What's really needed is a decent engine dyno type experiment where the output of the actual sensors on an optical CAS might be tested. Some effort spent on extending the drive and passing it through the engine's installed CAS onto a second CAS just used for the experiment would make a nice electro-mechanical engineering undergrad project.
I spun em up on a drill and still had the above mentioned problems. So it eliminated the belt theory.
I had a thought about that when you first mentioned it but didn't say anything because I'm not sure if it would be significant enough to cause any problems. But.....just in case.....AC electric motors do not spin at a constant angular velocity. They move at a range of angular velocities centred on the average velocity. For something like a power drill, I'm not sure how big that variation is relative to the average velocity. I think DC motors may also have some speed jitter (depending on the motor type - stepper motors certainly do).
As I said, possibly not relevant, but worth considering when designing experiments!
my car:
Looks like 1000rpm fluctuations on the last rpm pull which I assume is 3rd gear. I agree that's too much scatter, mine is only a few hundred rpm max which I can live with
We spun them at varying rpm and rev synch captured the triggering waveforms and saw that the optical sensors missed triggers and also moved the edges, as in the tdc trigger was moved ahead or behind a 24 pulse trigger if that makes sense. With the hall effect trigger on the cas there was no such discrepancy. It was exactly the same events that were occurring on the engine and they were occurring at the same time. So the conclusion drawn was that the optical sensor was the problem, seeing that the same issue is common place with rbs, I thinks its a reasonable conclusion to draw, and to solve the problem any hall effect setup off the crank or even a cam only hall effect trigger will work.
I have never seen a hall effect trigger system not work.
You're right - when doing back to back of what the optical does compared to the hall effect when both are driven the same way, then if one works and the other doesn't, you've proved that hall effect is better. I still wonder if drive speed jitter might (or might not) have an effect on exactly why the optical sensors don't work, but ultimately it doesn't matter. They're demonstrated to have a problem, and really that's all we need to know.
agree with you on this...we had this same wavey cas signal on the dyno...replaced it with another cas and no more wavey. the bearings on both cas were fine but the signal was different. initially thought it might be cas because when we put timing light on the marks were moving forward and back about 10mm.
Edited by Badgaz
Not sure on this only because the cas disc runs both cam (360) and crank (6) so ultimately if the cam belt is slapping away it still wouldn't affect the phasing or referencing of the cam to crank triggers because they are on the same disc. The two triggers are not separated by the cam belt. However by the optical sensor missing counts on the 360 cam triggers then you could see how the rpm trace variations occur. 3-10 missed counts and you have 3-10 degrees timing variations as can be seen on a few traced posted up. If the cam belt was slapping around at extreme levels then you would have other issues, but the rev signal trace itself would not be affected, as in, it would not change the phasing between cam and crank triggers because they are on the same disc
No I was talking in general about speed jitter - wondering whether diffraction effects might be affected by it and so on..... and this would extend to being driven by supposedly stable drives like a drill too.
One reason why the 360 slots might behave differently to the 6 slots could be because they are narrower. Would definitely affect diffraction (if diffraction was an issue).
This is how I made the cam bracket to hold a Honeywell gt101dc sensor and the trigger edge to bolt in place of the exhaust camgear washer.
Its all kept close to the gear and it attaches to the factory cas bracket.
Might help others if they want another way to go about it.
Nice work on your setup too mate! Another kit out there will certainly help the RB community.
  • Like 1
whats required to wire this up?
Ok guys I've had alot of PM's from people interested in buying a set once they go full swing so I've decided to compile a public list.
If you are interested in the second full batch post your interest and I'll add you to the list.
Currently the first batch has been delayed as the factory producing the first/sample batch has had no power since Sunday so they have not been able to ship my items but I was promised last night when I finally got them on the phone that they would ship today....
Cheers
Cameron
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
