Looking at getting a 350GT but after reading these forums I'm a bit skeptical.
I like the look of the 2008 350GT with Paddle Shift but scared about the studdering issue?
I could get a 2006 but then worried about the 8 speed gearbox packing up.
Is there a reliable 350GT or either way could I be looking at problems down the track?
https://www.sau.com.au/forums/topic/452176-v35-or-v36/
I'm in the same boat but because of budget ($10 to 14k)I've been mainly confined to searching in the 03/04 model range , I've looked at importing in order to get low K's and where there may be a better chance of a a trouble free vehicle as some of the issues seem usage related but this thinking has it's flaws also, I'm sitting on the fence at the moment.
I think if a good clean OE R34GT-t auto popped it's head up right now within my budget I'd probably go for it , I've had a manual one previously and like the car a lot--even though a good 350GT is probably a better car in so many ways.
Edited by BASHO
https://www.sau.com.au/forums/topic/452176-v35-or-v36/#findComment-7452353
Just avoid the V35 CVT if you don't want the problems associated with it.
It was only an option anyway.. you can still get the standard 5sp auto or 6sp manual on the V35 Sedan.
Or go with the KV36 (2008+) 370GT. (not sure which ones come with paddle shifters though)
https://www.sau.com.au/forums/topic/452176-v35-or-v36/#findComment-7452360
Ah. Is there a way of telling by looking at online auction photos which is a CVT model?
So you would recommend to stay away from the v36?
The CVT equipped V35 has paddle shifters on the steering wheel, and usually carries the name 350GT-8, although not on the actual badge on the rear.
I wouldn't have a problem with a 350GT V36 if I had the option and wanted an auto, the main reason I went for a V35 is because I wanted a 6sp Manual Sedan. If money wasn't an issue, I would look for a 2010+ V36.
https://www.sau.com.au/forums/topic/452176-v35-or-v36/#findComment-7452430
The stuttering issue? Is that on the 3.5s or the 3.7s? Not noticed anything on my 3.7
Would it be covered under dealer warranty in NZ? And I would also think a lot more mechanics would be able to fix up any issues on imports in NZ because of the different regulations and just the shear volume of them..... I know that when I had my R33, my local AUS Repco contacted their NZ collegues for the service and parts info. Were able to confirm things like the VL water pump being a suitable replacement part.
Wow just found an infinity in NZ
http://www.trademe.co.nz/Browse/Listing.aspx?id=824377307&open_homes=&region=&district=
I like the look of this.
This is a 350GT Type S with Infinity badges fitted... Steering wheel still says Nissan and I bet the stereo does as well... :-)
On the V36, anything with a S (Type S and Type SP) have the paddle shit and 18"'s. Type P has no paddle shift and is also on 17"'s
Edited by nickcorr
https://www.sau.com.au/forums/topic/452176-v35-or-v36/#findComment-7452483
I believe there was some issues on the early V36, but there was an ECU update to fix it, problem was Nissan Japan refuses to supply the update to Australian Dealers. If the car was recently imported, chances are it has had the update applied before it left Japan. Not sure if there is any easy way to tell though.
And yes, it is a Skyline. If it was an Infiniti, the steering wheel would be on the other side. I don't think there were any RHD Infinitis in 2008, but plenty of people that put Infiniti badges on their Skylines. They are the same car anyway.
https://www.sau.com.au/forums/topic/452176-v35-or-v36/#findComment-7452492
Fyi the dreaded CVT gearbox was only in 2001-2003 GT-8 sedans.
Yes, as mentioned, I am pretty sure there has never been a stuttering issue with 370GTs. And for a small extra amount of money, why would you not want the extra power anyway?
Be careful looking at cars from NZ - I have a feeling you cannot import them - -I remember something about them having to come straight from Japan, not an import of an import.
Talk to Iron Chef - he is by far the best bet to get the exact car out of Japan at the exact price you want. Once you start getting lists/photos/details of cars coming up for auction, it will blow your mind.
https://www.sau.com.au/forums/topic/452176-v35-or-v36/#findComment-7452516
I am fairly sure the CVT was available at least until 2005.. possibly through to the end of the V35 sedan run in 2006.
EDIT - yep.. 2006 - https://www.tradecarview.com/used_car/japan%20car/nissan/skyline/15080873/
Edited by sonicii
https://www.sau.com.au/forums/topic/452176-v35-or-v36/#findComment-7452523
So was this some approved used Nissan import vehicle? Like the Toyota Signature?
I had been lead to belive that these were all tip top vehicles.
Excellent work on hanging out fro the V36 as well... :yes: any pics?
https://www.sau.com.au/forums/topic/452176-v35-or-v36/#findComment-7459581
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
