Hey guys. Thought I would do a write up of the car I have been building for the past 2 years. Its a s1 s14. I have had a bit of bad luck with the car. Its had 2 paint jobs because the first paintjob was crap. The car should be running with the next 2 months.
Body:
Full respray in honda oddessy midnight purple.
Shaved engine bay
Navan front bar
Navan side skirts
Jdm rear bar
Navan rear pods
Jdm front gaurds
Orgrin boot lip
Ganador mirrows
Wheels: work vskfs
18x9.5 -6 with 215 35 achillies tyres
18x10.5 +1 with 235 40 achillies tyres
Suspension:
25mm extended lower front control arms
Nissan maxima tie rods and adjustable ends
Hardrace castor rods
Hardrace toe arms
Interior:
Genuine Bride zeta3 seats
Genuine Bride seat rails
7 point cusco bolt in cage with side intrusion bars
Hkb boss kit
Nardi deep corn steering wheel
Battery in boot
Engine:
256 camtech cams
Tomei cam gears
Gates timing belt
Engine accessories:
Rb26 cam covers, valley cover and timing cover. All dipped in lepored print
Custom catch and overflot tank in one
Solid engine mounts
Slide industies custom forward facing plenum
90mm throttle body
Spitfire coilpacks
Turbo setup:
6boost manifold
Garret gt35r
50mm turbosmart wastegate
Turbsmart boost tee
3" dump pipe
3" stainless exhaust with 5" tip
Manifold, rear housing, dump pipe and screamer all hpc coated
100mm thick intercooler
Custom alloy intercooler pipes
Fuel setup:
2000c bosh injectors
Walbro fuel pump
Surd fuel rail
Turbosmart 1200 fuel reg
Electrical:
Haltech ell v2
Racepak dash
Holden astra electric powersteering pump
Relocated fuse box to under the dash
Drivetrain:
Npc 10" button clutch
Custom gearbox crossmember
Solid gearbox mount
1 piece tailshaft
R33 r200 diff and 5 bolt shafts
I think thats about it. I will keep you updeated with the build.
https://www.sau.com.au/forums/topic/452189-rb25-s14/
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
