So after having my Blitz duel EBC sitting in the box for 3 years I finally got off my arse and installed it today. One thing has got me a little concerned thought. I noticed when installing it that it has only 2 wires - power and ground. I'm used to installing things with a fuse and also an ACC wire too. Sure enough, I reconnect the battery and "bing" boost controller is on.
Now Im sure Blitz aren't stupid and they have been making these things for years, but what kind of draw will this thing have on the battery? Is it perfectly ok that its always on like this?
Who else has one and noticed this?
thanks
I would have assumed this, but the instructions state to connect to power and not ign. Im wondering if it would loose settings if power was lost, ie if it was connected to ign and you turned the car off. Any ideas?
it assumes a person that is installing it has some common sense..
this means you will need to connect it to your ignition +ve & fuse it, alternatively (I've seen it done with other workshops).. connect it to your headunit's ACC power without a fuse.. as you're essentially using the headunit's 10 amp fuse..stupid option because when you leave your keys in ACC to listen to music your EBC is on.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
