No troubles, glad the tip worked out for you :)
And with not being able to change cars I have no idea why not, last year I thought people were able to change. Perhaps taken out in part of an update? Will look when I set up the next race to see if there is anything about it.
i have tried to change cars after entering the session before and it just won't let you. i think it's best to know which car you want to drive before you join the group practice!
  • 3 weeks later...
A small turn out tonight for Phillip Island. But I'm sure the drivers had fun either way :) Here are the results -
11096469_10153869993739386_3769268721039
Championship points for the SViRC stay the same as this was a no points round and the standings points in the iRacing league have been adjusted to suit.
Hope to see you all back next month for the next round of the SViRC :)
  • 4 weeks later...
Keen to give this a go. Can I just jump in during the season?
You can indeed, just head to http://members.iracing.com/membersite/member/LeagueView.do?league=1089 and join up. Next race is on the 6th of May. See you on track then :)
I just applied keen to try my (not so good) skills!
use that link above to find the series page and join up, I'll add requests later tonight for people. Till then have fun and try not get to addicted to iRacing ;)
I think part of my problem is that I was overturning my wheel passed the cars lock, so once the car gripped after oversteering the entire corner, i couldnt rotate the wheel quick enough to correct and it would just throw the car into a spin. Need to play around to get the wheel 1:1, but limit the range to the car (somehow).
tyres on the car were well and truly stuffed by halfway through the race.
Ok so results for tonight's round are in. Congrats to Jonathan Gage who was a mile a head of the field and took first. Was a great race with plenty of action and lots of fun!!!
11233584_10153957116449386_4246919868807
11203602_10153957116419386_7279786595504
And as for the season standings -
11041143_10153957116404386_3707982896645
Looks like I'm out tonight, went to change car and couldn't get back in :(
Thankfully I was able to get back in!!! Couldn't change car though had to stick with the mx5. :( lol
I couldn't get in at all, Been tryingsince half past. it's been telling me I can race now when I click on Liams page but nothing happens. Can get into testing just fine :/
You need to go to the league page and join the race from there, find the session and after 8pm click the green steering wheel on the right.
iRacing leagues can be a bit confusing at times try a couple of times with other hosted/league races to get the hang of it.
Was a frustrating race for me! Span twice and came off at turn 3 and had to try and recover my position. Was too hard keeping up with you 3 leaders at the start.
What's with the ford randomly over steering massively mid corner! Was scary to push it
Is there any way we can change setup for these races or is it fixed?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
