No troubles, glad the tip worked out for you :)
And with not being able to change cars I have no idea why not, last year I thought people were able to change. Perhaps taken out in part of an update? Will look when I set up the next race to see if there is anything about it.
i have tried to change cars after entering the session before and it just won't let you. i think it's best to know which car you want to drive before you join the group practice!
  • 3 weeks later...
A small turn out tonight for Phillip Island. But I'm sure the drivers had fun either way :) Here are the results -
11096469_10153869993739386_3769268721039
Championship points for the SViRC stay the same as this was a no points round and the standings points in the iRacing league have been adjusted to suit.
Hope to see you all back next month for the next round of the SViRC :)
  • 4 weeks later...
Keen to give this a go. Can I just jump in during the season?
You can indeed, just head to http://members.iracing.com/membersite/member/LeagueView.do?league=1089 and join up. Next race is on the 6th of May. See you on track then :)
I just applied keen to try my (not so good) skills!
use that link above to find the series page and join up, I'll add requests later tonight for people. Till then have fun and try not get to addicted to iRacing ;)
I think part of my problem is that I was overturning my wheel passed the cars lock, so once the car gripped after oversteering the entire corner, i couldnt rotate the wheel quick enough to correct and it would just throw the car into a spin. Need to play around to get the wheel 1:1, but limit the range to the car (somehow).
tyres on the car were well and truly stuffed by halfway through the race.
Ok so results for tonight's round are in. Congrats to Jonathan Gage who was a mile a head of the field and took first. Was a great race with plenty of action and lots of fun!!!
11233584_10153957116449386_4246919868807
11203602_10153957116419386_7279786595504
And as for the season standings -
11041143_10153957116404386_3707982896645
Looks like I'm out tonight, went to change car and couldn't get back in :(
Thankfully I was able to get back in!!! Couldn't change car though had to stick with the mx5. :( lol
I couldn't get in at all, Been tryingsince half past. it's been telling me I can race now when I click on Liams page but nothing happens. Can get into testing just fine :/
You need to go to the league page and join the race from there, find the session and after 8pm click the green steering wheel on the right.
iRacing leagues can be a bit confusing at times try a couple of times with other hosted/league races to get the hang of it.
Was a frustrating race for me! Span twice and came off at turn 3 and had to try and recover my position. Was too hard keeping up with you 3 leaders at the start.
What's with the ford randomly over steering massively mid corner! Was scary to push it
Is there any way we can change setup for these races or is it fixed?
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
