Wtb R32 4 Door/sedan
  • 3 weeks later...
Did you work out what the funny sound Is when it starts spooling up I drove there from Newcastle to have a look and couldnt come up with the cash in time I would of msged him about a week after you got it..........
Would you be interested swaps for a r32 4 door sedan with a lot of money spent on it and a lot of engine work
Or a genuine Vl Calais
Or cash price
Well I have my other 4door, which was written off, which was pretty clean & have swapped over coilovers, rear camber arms, tie rods and stuff. Went through the stereo & replaced headunit. And put my s2 rear lights on it. Changed my seats over and various parts of the interior to clean it up. Replaced climate control module & instrument cluster bulbs for leds, & now all lights on dash work, & i tinted the windows. There's other little bits too, just trying to get it to how I had my other one. Only thing left to do now is put my motor into it. Just want to make sure eveything is sorted first.
R32 skyline sedan
Rb20det
Hd clutch
Power FC
550cc injectors
Z32 afm
Turbo smart boost t
Power spirit 3076 turbo
Pod filter
Front mount Intercooler
Stainless steal dump pipe
Walbro fuel pump
silicone radiator hose
Nismo thermo stat
K&n oil filter
New fuel filter
New battery
Spitfire coil packs
Gtr fuel resister
Boost gage
Turbo timer
Digital speedo
New thrust bearing
New spark plugs
Cusco Adjustable rear camber arms
Cusco adjustable front camber arms
Drift works hicas delete kit
subframe c lock collars
Coilovers
Smoked blinkers
Bonnet cut to look like gtr bonnet with carbon n1 lip
Vertex body kit
Few other things
 Share
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
