Gidday,
I have done a 25det engine replant in my r32 and have kept my old front strut brace in place but have noticed that strut brace only just clears the engine by about .5mm!
I have raise the strut brace as high as it will go, and slid the engine mounts as far down as they go and have only got .5mm of clearance between TPS and the brace.
So, this leaves me worried as engines under load torque or twist the same way the crank spins, especially the rubber r32 engine mounts, so do i take the brace off and let the engine do its stuff or keep it on and when giving it heaps and let the brace flight against the twisting of the engine?
If left on could this be bad for the struts and rip the brace off the threads? or would it be oky?
im not sure what to think of this.
:cheers:
The engine actualy twists the opposite direction to how the crank spins (anti clockwise)
Take the strut brace off, problem solved.
Or take it off and give it a bend in the middle, its not doing much anyway, morso if you want it there for looks.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
