Hey guys,
Thought it was time to share the progress from the last year of building a bare 33GTR shell into a drag car.
DTP motorsport has done all the car repairs and fabrication work. U can find more pics on there Facebook page of the build.
The Engine is by JHH racing and is Rb30-3.2L, Precision 8685, Hypertune, RIPS 4WD glide, Motec ect ect
I have a ton of pics so ill keep them coming as i can.
Started out in pretty average condition unfortunately but we got it straightened out.
Trust Drag cooler purchased from NXTIME.
Very minimal cutting required to the bar as we got the 165mm thick cooler right back.
Converting to manually operated windows. Mixture of Daihatsu applause and gtr mechs did the job.
Peterson 2.5 gallon tank fitted.
Custom fuel tank in progress
Parachute anchor point.
Glass installed
Seat bracket for the kirky race seats we got powder coated black.
RIPS NZ transfercase pump setup on custom bracket
Early model Rb20 converted for dry sump setup.
Brackets about to get sent off for coating.
Motec Can pad and bracket.
Installing the stretch carpet
Laying down carbon fibre matt ready for the hardener to be applied for the interior panels.
  • Like 2
https://www.sau.com.au/forums/topic/452268-r33gtr-drag-car/
Oil and fuel pump mount in progress.
New pillow ball bushes installed
ARP extended bolts pressed in place.
Rear cradle was strengthened powder coated and installed with Gktech adjustable arms top and bottom
The brains of the outfit getting mounted.
The box on the right side is for power management to control solenoids, fans, pumps, lights ect.
Complete RIPS AWD 2SPD setup arrived.
Manifold underway.
These turbosmart gates have sensors mounted in the top hats so there movements can be logged.
Decided to keep it GT42 frame size if i ever wanted to downsize in turbocharger i could so i went for a Precision 8685 1.28.
Removed the standard GT42 type compressor outlet flange and replaced it with a vibrant 3.5"clamp.
Edited by Ryan1200
  • Like 3
https://www.sau.com.au/forums/topic/452268-r33gtr-drag-car/#findComment-7455048
Sick build!
I think Mike is confused as you posted a picture of the valves and valve guides, then mention valve seats. ( which were fitted to head on next photo)
Really looking forward to seeing this one!
https://www.sau.com.au/forums/topic/452268-r33gtr-drag-car/#findComment-7456559
Sick build!
Thanks mate!! Its defiantly been a long build we started to assemble the car earlier last year but been collecting parts for about 3 years now so its been a long process.. Got a ton of pics to get through thats for sure!! :thumbsup:
https://www.sau.com.au/forums/topic/452268-r33gtr-drag-car/#findComment-7456589
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
