Cheers mate. Was working on it every day from about mid October to Xmas but the motors has been a long process maybe 2 years we used lots of non off the shelf bits which took awhile to complete and I wasn't in a hurry because the car wasn't done anyway. Hopefully around 2months fingers crossed ready for tuning.
I am newish to all of this and think you blokes have great patients, I am struggling to handle 4 months of being treated like a mushroom ,lol
Guess when you are hands on it is more personal and interesting and time just gets eaten up.
I get impatient waiting for other blokes builds to be finished :)
What you need to do then is buy yourself a second one incase of this type of situation haha :cheers:
Cheers. It's actually a Mazda 6 colour. When in the sun it's quite a bit lighter in person.
Had 2 300ZXs, one was red the other more maroon and that was a better colour for that car..
I think it is David that has a red R and looks amazing a well :)
Said I would never have a black car, but have one, looks great just cleaned, but give it 10 minutes :( ,LOL
  • Like 1
  • 2 months later...
  • 3 weeks later...
Checking bulk head connectors facing correct directions.
Rips gearbox adaptor plate and engine mounts back from HPC
Ran the fuel line through the rail to keep clear of the exhaust, driveshaft and to keep the line straight as possible to hit the mechanical pump at the right height.
New chopper wheel fitted to tailshaft.
Unfinished bracket to mount the new tailshaft sensor.
Auto trans outlet temp sensor.
  • Like 1
Hey guys,
I have a ton of pics so ill keep them coming as i can.
Converting to manually operated windows. Mixture of Daihatsu applause and gtr mechs did the job.
Great build mate,,,loving it actually.
I have a question for you,,,can you shed some light on how you did the window winder conversation?. I also need to do this and any help would be much appreciated.
Cheers
Neil.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
