Neil my fabricator did the conversion for me he spent quite sometime looking for the correct bits from the wrecking yard ect. The pic and the info i posted gives you a starting point for the bits to look for but if you wanted him to do a conversion for you just need to send him the GTR parts and he will send you back the bits fabricated ready for install. Last person that asked he said $400. Sorry i couldn't be more help. If you want his details let me know. cheers
Engines in progressing slowly but surely.
Completed wheel with terminated bulk head connector.
Speedflow bill this week :spank:
To avoid any problems associated with ethanol sitting in the fuel system for long periods we rigged up a fuel drain. The process will be drain the main tank add 98octane unleaded then connect into this quick disconnect fitting, rotate tap into off position which blocks return line feeding the tank then crank engine to purge remaining fuel in the lines and rail nice and easy.
Fingers crossed some bigger updates coming next week.
  • Like 2
What coils are you using ?
I'm looking at an upgrade at the moment and will most likely just go the LS2 route, I just noticed you have gone something else
Mick I'm running Honda Cbr bike coils with a CDI module powering them. Since buying the equipment i've heard some mixed opinions on the reliability of these coils so ill play it and see how they go. Being a complete OEM system with built in ignitors i think the LS2 route would be a pretty good option.
  • 4 months later...
  • 1 month later...
updates?
Yep updates coming finally got some spare time on my hands to start getting it ready for tuning... January is the target real keen to get it out for some roll racing at willowbank... Hopefully the smaller brakes to suit the 15" rims pull it up going into turn 1 >_<
Just pull the 'chute... ;)
Found some second hand SSR's rims which we refurbished after making them fit. Took plenty of messing around though had to push the rim further into the guard by spacing the rim inwards by the way of 14" x 8mm ring that bolts between wheel center and rim. The 275/60 is 28" tall so placement needed to be spot on.
Just back from powdered coating today should look ok. :wub:
SP1's 15"x 9"
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
