This is totally insane! Your attention to detail is staggering. So awesome.
Could you please PM any other pics you might have of that crossmember ? (Please) :-)
Also could you please take x1000 photos showing absolutely everything once its complete so we can all have some alone time with some good material :-)
Cheers man thanks for the nice comments. Probably my last big build so i thought id build it properly ;) haha.
Next time its on the hoist ill get some more pics of the crossmember for you RIPS does awesome work.
Ill have some more pics for sure over xmas time.
  • Like 1
  • 3 months later...
No real progress was made over xmas unfortunately way too much beer consumed :/
What i did decide on recently was to upgrade from the M800 to the new M150.
Unfortunately we needed to change CDI modules as the M150 wouldn't talk to the Motec CDI8... Yes i know :angry2:
New bits arrived today. :cheers:
And the good news is the car was delivered back to my good mate / fabricators last night to continue on with last few bits of work left.
Updates over the next few weeks..
  • Like 1
Great looking car and fantastic build - looks like you've thought of everything. Plans for anything other than the 1/4 mile?
I hope so although i always seem to find something new and improved id like to add haha thanks mate.
I really wanted to build this as a street going car but rules and regs and police just make it so hard now.
Apart from the 1/4mile stuff it's just a car to go out and have some fun in, events like roll racing and powercruise both of which don't require registration.. Powercruise u can take passenger so that should be fun haha.
What would've been cool are the Motive GTR drag battle and new 1/2mile but both require registered cars for insurance purposes unfortunately...
Struggling at the moment to find room for a large enough air filter. The car was built with the intensions of not running one but i chickened out and purchased a 7" round 16" long K&N but looks like it won't fit where i was hoping without some more mods moving stuff around and re-coating the intercooler :/
  • 1 month later...
Yep been progressing slowly but surely.
Under dash harness re-pinned for the M150 and re-installed into the car. Lucky we did bulk head connectors on the firewall made removing the harness easy and saved engine harness removal.
Final fitment of the oil and fuel pumps.
Oiling system completed.
More updates tomorrow.
  • Like 1
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
