Hanzie Posted January 3, 2015 Share Posted January 3, 2015 Hey, i have just finished installing a new head gasket for the first time on this engine, i am about to install the intake plenum and air ducting, but i still have these 4 brackets left to attach, im not sure where abouts they go, and i dont want to put the plenum on before putting the brackets on, if someone could point me in the right direction that would be helpful, if possible could someone post pics? Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/ Share on other sites More sharing options...
Hanzie Posted January 3, 2015 Author Share Posted January 3, 2015 The black bracket on the top right has been located and installed I think the bottom left bracket may go just above the exhaust manifold?? Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/#findComment-7454412 Share on other sites More sharing options...
Aggroman Posted January 4, 2015 Share Posted January 4, 2015 top left and bottom right attach to the lower side of the intake plenum.. Bot right is central holding knock sensor cable and attaches to the big part of the loom top left goes near firewall, the little notch against the plenum it should be straight forward from there Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/#findComment-7454760 Share on other sites More sharing options...
Hanzie Posted January 4, 2015 Author Share Posted January 4, 2015 So would it be easier to install the plenum first then the brackets? I'll be be working on the car tomoz so ill be able to have a better look, I appreciate your help a tonne! Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/#findComment-7454820 Share on other sites More sharing options...
Hanzie Posted January 4, 2015 Author Share Posted January 4, 2015 And was I right about the bottom right bracket going above the exhaust manifold? Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/#findComment-7454821 Share on other sites More sharing options...
Aggroman Posted January 4, 2015 Share Posted January 4, 2015 bottom left goes on the manifold as part of the heat shield. My advice is to put the lower half on and connect what you can... If you look at the bottom half you will see all the associated holes with thread in them, they almost line themselves up when you do it all. Looking at it again I think the top left one goes towards the front end and holds the grey injector loom plug and helps with the TPS wiring and such Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/#findComment-7454837 Share on other sites More sharing options...
Hanzie Posted January 4, 2015 Author Share Posted January 4, 2015 Do you mean the bottom right goes towards the injector loom and tps wiring? And top left goes on the plenum? I just wanna make sure cause I think you may have meant to say bottom left instead. Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/#findComment-7454859 Share on other sites More sharing options...
Hanzie Posted January 4, 2015 Author Share Posted January 4, 2015 Or you may be right and it has that nipple kinda plug that you have to pinch in the holes and then expands to secure itself? Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/#findComment-7454860 Share on other sites More sharing options...
Hanzie Posted January 10, 2015 Author Share Posted January 10, 2015 All but the bottom right go on the exhaust manifold, and the bottom right goes above the injector closest to the firewall, hope This helps someone in need later on Link to comment https://www.sau.com.au/forums/topic/452290-rb25de-bracket-locations-help-needed-pictures-included/#findComment-7458517 Share on other sites More sharing options...
