Just would like to know if ppl still using spiltfire coil packs or what is better?
I started to get miss after 7krpm install a hks twin power (helped) then the miss came back after a few weeks, does it all time same
Rpm range. New plugs fitted and gapped to .8 and spiltfire coils about 6 yrs old and about 30,000kms on them. All brand new engine harnesses...also boost is about 22-23psi
https://www.sau.com.au/forums/topic/452302-rb26-500rwkw-coil-packs-issues/
E85 or?
What plugs and heat range are you running?
Was it OK for a while and just started or has it been happing from the start?
Have you checked the Spitfires for arcing?
Is it missing when hot?
use copper plugs at 8 heat range from memory, Check coils, make sure your alternator is pumping out decent amperage, flog hks twin spark off and buy Morris tech igniter
Ditch that pos pretty gold HKS box.
For those of us that missed the bulletin what is wrong with the HKS DLI II ?
That hunk of junk cost me two sets of coils. Ditched it along with the factory and used the above mentioned ignitor and issues disappeared.
The factory ignitor is an electrical bottle neck.
That and it's more expansive and harder to get then the Morris tech ignitor
Paul's making 480rwkw with no more then spitfires and a Morris tec ignitor.. I'd be right in assuming that the plugs are copper, heat range 8 gapped at .8 (I may have put the last set in?)
This business of reducing the gap of the plug down to nothing and reducing spark size is a bandaid fix and simply ridiculous
I can't tell you how but I had a new set of OEM and a set of split fires both kick the bucket within 3-4k kms. Ditch the lot and it's all good.
Joey had issues at 400 rwkw, put the ignitor on and done.
I've sent a few of these around the country and on every car the ignition issues disappeared.
I know of at least 8 GTRs with 500awkw+
3 GTRs with over 600awkw
3 GTSTs with over 500rwkw
All with Splitfires and NGK copper plugs. Plug gap is critical and all plugs must be spot. The difference between a .6 and a .65 gap is noticeable when you start going cranking the boost.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
