Just would like to know if ppl still using spiltfire coil packs or what is better?
I started to get miss after 7krpm install a hks twin power (helped) then the miss came back after a few weeks, does it all time same
Rpm range. New plugs fitted and gapped to .8 and spiltfire coils about 6 yrs old and about 30,000kms on them. All brand new engine harnesses...also boost is about 22-23psi
https://www.sau.com.au/forums/topic/452302-rb26-500rwkw-coil-packs-issues/
E85 or?
What plugs and heat range are you running?
Was it OK for a while and just started or has it been happing from the start?
Have you checked the Spitfires for arcing?
Is it missing when hot?
use copper plugs at 8 heat range from memory, Check coils, make sure your alternator is pumping out decent amperage, flog hks twin spark off and buy Morris tech igniter
Ditch that pos pretty gold HKS box.
For those of us that missed the bulletin what is wrong with the HKS DLI II ?
That hunk of junk cost me two sets of coils. Ditched it along with the factory and used the above mentioned ignitor and issues disappeared.
The factory ignitor is an electrical bottle neck.
That and it's more expansive and harder to get then the Morris tech ignitor
Paul's making 480rwkw with no more then spitfires and a Morris tec ignitor.. I'd be right in assuming that the plugs are copper, heat range 8 gapped at .8 (I may have put the last set in?)
This business of reducing the gap of the plug down to nothing and reducing spark size is a bandaid fix and simply ridiculous
I can't tell you how but I had a new set of OEM and a set of split fires both kick the bucket within 3-4k kms. Ditch the lot and it's all good.
Joey had issues at 400 rwkw, put the ignitor on and done.
I've sent a few of these around the country and on every car the ignition issues disappeared.
I know of at least 8 GTRs with 500awkw+
3 GTRs with over 600awkw
3 GTSTs with over 500rwkw
All with Splitfires and NGK copper plugs. Plug gap is critical and all plugs must be spot. The difference between a .6 and a .65 gap is noticeable when you start going cranking the boost.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
